Nintendo Wii Fit - Balance Board + Game Console Logo
Posted on Jan 28, 2010
My wii fit board won't connect with tv is the blue light suppose to stay on all the time or flash
Anonymous
Level 1:
New Friend:
  • Contributor 13 Answers
  • Posted on Jan 09, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
13
Questions
0
Helped
1924
Points
39
Hi, thanks for using Fixya!
  • Open the SD card slot on the nintendo wii, open the battery panel on the wii balance board.
  • Press the two red sync buttons on the wii console and the balance board and hold for 3 seconds.
  • The blue light on the back of the wii balance board should flash for 5-10 seconds and then stay blue.
  • If this doesn't work then try changing the batteries and trying again.
If it still isn't connecting then the problem is something a proper nintendo expert will have to help fix.
Thanks, I hope I have been of assistance.
3helpful
3answers
The wii balance boards light will just blink but won't stay on I need help ? thanks!~Embrio Anderson ????
It's either not establishing a connection with the Wii, or it's batteries need changing. I personally have never had to connect a balance board with the Wii for the first time, I only played with it at my friend's house.
1helpful
Won t turn on with the wii fit game replaced batteries twicw
I AM NOT GOING TO AWNSER YOU Q BUT I CAN TELL YOU THAT THAT IS THE SAME THING THAT IS HAPPING TO OUR SO IF YOU GET THE SOLUTION BY ANY CHANCE WILL YOU LET ME KNOW
10helpful
Wii fit board won't stay on light flashes on and off just put in new batteries
there is a red button underneath the battery cover this is the sync button there is one on the wii console next to the sd card solt hold both of them and the same time until they are connected this will allow the wii board to stay on
22helpful
2answers
My wii fit balance board keeps blinking but will not stay on. batteries are good. cant find my instruction book. what could be my problem????
follow this
  1. Insert a Wii Balance Board compatible game disc in the Wii console.
  2. Use the Wii Remote to select the Disc Channel from the Wii Menu, then select "Start" to begin the game. Press the A Button to bypass the wrist strap screen.
  3. Open the small SD Card slot cover on the front of the Wii console.
  4. Remove the Battery Cover on the bottom of the Wii Balance Board.
  5. Press and release the SYNC button on the Wii Balance Board. The blue light on the board will start blinking.
  6. Press and release the red SYNC button on the Wii console while the blue light on the board is still blinking.
  7. The blue light will stop blinking and stay on steady once the syncronization is complete.
5helpful
Bought 2nd hand wii fit, have just loaded disc and replaced batteries in board but power light not staying on board, flashes for about 30 seconds and then switches off. Does it need to be synchronised with...
    Hope this helps
    Try these steps!
  7. The blue light will stop blinking and stay on steady once the synchronization is complete.
please leave a good rating and testimonial if you appreciate my help. THNX
9helpful
3answers
Wii board
Make sure that you have synced the board to the wii (similar to a controller). You have to take the battery cover off the board and push the sync button. The blue light will start flashing. From there you need to open the front cover of your wii under the power button.
From there you start up wii fit and it will prompt you to turn on your board. You should get a solid blue light. If you don't, you may need to try syncing again.
5helpful
Havent used board in a while now wont start up. changed batteries didnt help. flashes blue but doesnt stay on
It likely needs to be resync'ed since it hasn't been used in a while. The flashing lights show it is trying to connect to the Wii...if they never turn to a steady blue, it never connected. A sync should correct the problem.
First press the red "sync" button on the front of the console, then inside the battery door of the Balance Board. The results should be immediate. If the board never holds a steady blue light after trying to sync, you problem is something else that I couldn't guess!
I hope this helps!
2answers
My wii fit board blue light will start flashing but will not stay on.I have replaced batteries but still wont work.
test it on another wii, if you cant then call Nintendo support, it depends on the blinking really.. its probably doa... dead on arrival or something,..
2answers
Wii fit board will not stay on
The light does not need to stay on. It is supposed  to flash approx. 3 times, then go off. Though the light is out, the game balance board is still on.
23helpful
3answers
Power
    Try these steps!
Top Nintendo Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Aron
Sean Wright
Sean Wright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
