This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
more often the element burns out before the selector switch. If there is an indicator lamp that illuminates when you turn it on and the light isn't coming on then it could be the switch.
There is no doubt that it is the element that has failed, so all you need to do is replace the fan oven element.
If you can see a removable panel at the rear of the oven ,remove that, and you should see the element.
Remove and replace.
If ther is no removable panel then you will have to access it from the rear of the oven cabinet.
Plz rate my solution.
thanks,
Reset the clock that will make the heating element work, if your clock has stopped displaying (common fault) set as per instructions but you wont be able to set at any acurate time.
silly boy!
the element is probably ok as what you did will not damage it.
the green/yellow wire should go to the base plate and if there is no connector for it, just use one of the fixing bolts. the other two wires go to each end of the element
Dear Friend,
ngfam1 at your service
I am happy to assist you!!!
Discount Parts Major Appliance & Consumer Electronic Parts.TOLL FREE 1-(888)-338-37908:00AM - 12:00 MIDNIGHT7- DAYS A WEEK NEXT DAY DELIVERY IF IN STOCK!
Here is the service company I refer my appliance customers too!
A&E Factory Service
A Nation Wide Company. / Available 24 / 7 for arranging appointments! In the USA.
1(800) 905-9505
If this dryer is 10 years old or more do not spend any money on it!
The new ones are much more efficient! If you have to replace it buy a Speed Queen , it will do 8 loads a week for 25 years!
It's the last washer and dryer I will ever buy!!!! And less expensive than a top of the line unit!
You will be fine now!
Bless you,ngfam1
PS. PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OFF!
This is late response but this fault is your fan element. You have two of them, if heating slower than usual, it is only one that has failed. When replacing one, it is recommended the other one be replaced. Tripping the circuit breaker is the symptom. These elements 2100 Watt each are anywhere between $70 to $110.
Service Tech.
