20 Most Recent
Smeg SUK61MFX Gas Kitchen Range Questions & Answers
We replaced the blown oven light with a like for
Just had the same thing after cleaning the oven. Mostlikely, the upper hinge on the left side of the oven door is out of alignment and not hitting the switch. Take the door off and gently bend the upper arm of the hinge inward and it should hit the switch. Otherwise, take of the left side panel (really easy, 6 screws) and you can see for yourself how the upper arm of the hinge hits/ should hit the swithch.
OVEN USED WITH BROKEN DOOR SEAL, OVEN HEAT HAS
hello sir/mam
good you have changed the door seal but you cant do the wiring because if the wires are fully burnt it is difficult to notyfy which wire is connected to which part of the oven so please call the engineer he will do it.
Rear circular element not working
more often the element burns out before the selector switch. If there is an indicator lamp that illuminates when you turn it on and the light isn't coming on then it could be the switch.
I need users guide
I need to replace oven light bulb for Smeg gas oven range cook unable to take cover off to get at bulb any ideas how this is done?
Smeg SUK91MFX5 oven wont heat
Reset the clock that will make the heating element work, if your clock has stopped displaying (common fault) set as per instructions but you wont be able to set at any acurate time.
Cooling fan
Dear Friend,
ngfam1 at your service
I am happy to assist you!!!
Discount Parts
Major Appliance
& Consumer Electronic Parts.
TOLL FREE 1-(888)-338-3790
8:00AM - 12:00 MIDNIGHT
7- DAYS A WEEK NEXT DAY DELIVERY IF IN STOCK!
Here is the service company I refer my appliance customers too!
A&E Factory Service
A Nation Wide Company. / Available 24 / 7 for arranging appointments! In the USA.
1(800) 905-9505
If this dryer is 10 years old or more do not spend any money on it!
The new ones are much more efficient! If you have to replace it buy a Speed Queen , it will do 8 loads a week for 25 years!
It's the last washer and dryer I will ever buy!!!! And less expensive than a top of the line unit!
You will be fine now!
Bless you,ngfam1
PS. PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OFF!
My Smeg gas oven lights up when I press the knob to light but as soon as I release the knob the flame dies?
Question edited for clarity.
The thermocouple safely device needs replacing. It's job is to make sure there is a good pilot flame before opening the main burner valve. When they fail, the flame goes out. You can try holding the knob longer, or just call for service and have it replaced. It is a gas appliance so should only be worked on by a gas certified technician. It is a fast job, in and out in 30 minutes, so call out plus the part.
OK for smeg gas stove circuit wiring diagram mode3 C9GGSSA-1
As an AI language model, I do not have access to specific product information or wiring diagrams. It is important to obtain the correct wiring diagram for your specific model of gas stove to ensure proper and safe installation. I recommend consulting the user manual or contacting the manufacturer or a licensed electrician for assistance.
Smeg gas hob, 2 burners have very low flame
If two burners on your Smeg SR275XGH2 gas hob have a very low flame, it may indicate a problem with the burners or the gas supply. Here are some steps you can try to fix the problem:
- Check the gas supply: Make sure that the gas supply to the hob is properly connected and turned on. If the gas supply is off or disconnected, the burners may not function properly.
- Check the burners: Check the burners for any visible damage or blockages that may be causing the low flame. Make sure the burners are clean and free of any debris or foreign objects.
- Check the gas pressure: Make sure that the gas pressure to the hob is set correctly. If the gas pressure is too low, the burners may not function properly.
- Check the connection: Make sure that the connection between the hob and the gas supply is secure and not damaged. If the connection is damaged, it may cause the burners to function improperly.
- Contact technical support: If the above steps do not help, you may need to contact Smeg or a technical support team for further assistance. They will be able to diagnose the problem and provide you with the necessary support.
It is also a good idea to check the documentation or manual that came with the hob for any troubleshooting tips or recommendations.
Smeg range cooker with induction hob e4
Hope this helps!
The issue is that the control board requires reconfiguration.
Firstly switch off the appliance and disconnect from the mains.
Reconnect and Press and Hold the Minus key '-'
While holding the minus key press keys 1 through 4 in turn within 4 seconds. Each key press will give an audible beep.
Once done you should get a 'C' displayed for each ring element.
Now place a pan of water on one element. Press the Plus key '+' next to the element ring and wait for the 'C' to change to '-'.
Repeat that for each element and once complete the appliance will switch off.
Reconfiguration is now complete and you can use the appliance as normal.
