SOURCE: my phone wont turn on anymore
Hey men i can fix ur phone... if u want contact me. [email protected]
SOURCE: charging error, stop charging! with "!"
I have had this problem before so dont worry, i found that i had to take out the chip and batery and air it out aswell as the the place were the charger fits, place them back in and try to charge up again.
SOURCE: my sony ericsson w700i are not connecting by usb cable with pc
you may not have the proper drivers installed on ur computer for your phone.
Insert the cd u got with ur phone and install drivers for your phone..
SOURCE: Sony erricson w705, wont charge the battery, it
my phone is the same model and did this but when i charged it, after about an hour it would come up with 'charging error stop ' and when i unplugged it, it hadn't even charged at all. and then the other day it just wouldnt charge, i plugged it in, it said it was charging but it wasnt. in the end, it worked by keeping the phone switched off and charging it while i was turned off. so try that, if not then i really dont know sorry
you might need to install a mobile phone suite which is a program that will let you install a mobile phone to a computer this will have to be specific to your phone there are a number of phone suites nokia Samsung sony ericson to name a few here is a phone suite link hope this helps
http://global.mobileaction.com/product/product_USB.jsp#bottomContent
Turn on the Bluetooth device from which you want to transfer files from or to.then turn the bluetooth of your samsung mobile..In most samsung mobiles the bluetooth can be turned on by going into applications where you can find bluetooth.
Press the "Search New Headset" button and allow the phone to search for the Bluetooth device. Once the device has been found, highlight it and press the "Select" button.
then you can transfer the files you want by going into options and then selecting the option of transfer via bluetooth.
