20 Most Recent
Sony Ericsson S302 Grey +1GB Unlocked FedEx +Gift + Wty Cell Phone Questions & Answers
Do not charging
First Option:mostly nokia chargers doesn't make problems...just try the following..connect ur mobile with a system (usb cable)...found out whether it is charging or not...if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...if it charged with usb cable buy a new chargerPlease change Phone Bettery and check the chargingIF Charging Problem not Solved SoSecond Option:Your Phone charging IC Fault So Please change charging ICAnd charging Problem will Solved Quickly
Themes problem
download the themes that are compatible to your phone model.. you can go to this website.. mobango.com.. free-symbian.com.. etc.. its free so its legal.
Loss mobile,
reported in police, please tress my
Ifyour
mobile phoneis lost or stolen you can inform your cell phone provider with your IMEInumber. Your cell phone provider can then put the serial number on a shareddatabase. This list stops this particular phone from registering on any networkand will be useless for anyone even if the mobile phone's
SIM cardis changed.
It is not possible to trace your cell phone, even if you hadsetup a tracker program on the phone, it can only give the location of yourcell phone in the coverage area where the cell phone transmitter tower islocated.
Your best bet is to ring your cell phone and hope the person who answers yourcell phone will return your phone to you.
Otherwise I suggest you contact your cell phone providerASAP. To lock/block your cell phone from further use, please click on this link:-
http://www.fixya.com/support/r5057854-lost_or_stolen_cell_phone
Will it support themes??
Yes It will support themes.You can download themes from online by searching sony ericson s302 themes get it for free download
My sony ericsson s 302 does not support jar files
s302 supports most of the games of nokia phones excluding the symbians. but in the case of the softwares the case is similar to wat u said.....wat to do dear,... if u need more support.....do hav another gud one :)
How can i install different softwares in s302???
You just want to connect your Phone to your PC, (Via Cable, IR, Bluetooth) Anything you have.
If you are on IR or Bluetooth, just send the .jar file to your phone it will receive it, and then ask you to install it.
And if you are on Cable (USB) then when you will plug-in you phone the phone will ask you few options, Select File Transfer, after that you will see a Removable Drive in you "My Computer", enter in it, you will see different folders like Sounds,Videos... Enter a folder names Others, and paste the .jar file there. Remove the Cable, and In you Phone Menu Enter File Manager > Others, you will see the file there run it, it will be installed.
I Hope this will solve your Query.
If I was helpful, Kindly do Rate!
Regards,
Waqar.
