Receive Mode Settings
Select from the following receive mode options to suit your needs. Once you've decided on which receive mode to use, follow the
below instructions to set the receive mode using the operation panel.
- Press the <FAX> button to enter Fax mode.
- Press <Menu>.
- Press the right or left arrow button to select [Receive mode settings], then press the <OK> button.
- Press the up or down arrow to select the receive mode that best suits your needs, then press <OK>.
Types of receive mode
Select the receive mode according to your needs.
Receive mode
Purpose
FAX/TEL AUTO SW
When you want to receive faxes automatically as well as voice calls.
FAX ONLY MODE
When you want to receive only faxes automatically with your machine, or have a dedicated telephone line for FAX use only.
DRPD
When you have subscribed to a DRPD service with your telephone company.
MANUAL MODE
When you receive mainly voice calls and sometimes faxes, or want to receive faxes manually.
ANS.MACHINE MODE
When you want to receive voice messages on your answering machine and receive faxes automatically.
FAX/TEL auto switch
FAX
The machine does not ring but will receive the fax automatically.
Voice call
The phone attached to the machine will ring. Pick up the handset to answer the call.
Note:
- Ring start timing and Telephone ring length can be specified in FAX/TEL auto switch in the Receive mode settings.
- If you want the telephone to ring when it receives a fax, connect a telephone to your machine and enable the Incoming ring settings in RX settings.
- The phone attached to the machine may not ring depending on the telephone type you are using.
FAX only
FAX
The telephone does not ring. The machine will receive the fax automatically.
Voice call
You will not be able to answer the call.
* If you want the telephone to ring, connect the telephone to your machine and enable the Incoming ring settings in RX settings menu.
DRPD
FAX
Your telephone line will ring according to the ring pattern you have chosen and receive the fax automatically.
Voice call
Your telephone line will ring according to the ring pattern you have chosen. Pick up the handset to answer the call.
Note: Specify the FAX pattern in the
DRPD: Set FAX ring pat. in
RX settings menu.
Manual RX
FAX
The
telephone attached to the machine will ring. Pick up the handset and if
you hear a beep tone, press the <Color> or <Black> button
on the machine to receive the fax.
Voice call
The telephone attached to the machine will ring. Pick up the handset to answer the call.
Note:
If you are far from your machine, you can use the remote receiving
function to receive faxes. Pick up the handset of the telephone
connected to the machine and press 25 (the remote receiving ID).Ans. machine connect
FAX
First
the answering machine connected to your machine will respond to an
incoming call, and then the machine will receive faxes automatically.
Voice call
The answering machine connected to your machine will respond to an incoming call.
Note:
- Set the answering machine to answer on the first or second ring.
- The entire message should be no longer than 15
Sorry for the confusion. Our problem occurs when we are having a voice conversation -- no faxes involved. Not trying to send or receive a fax. While we can't receive all telephone calls (for the above reason) our faxes seem to come in and send just fine.
