AOC LM729 17" LCD Monitor Logo
Posted on Jan 22, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My aoc model 729 lcd monitor displays windows start up but then says there is no signal.
wisiny.com
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • AOC Master 848 Answers
  • Posted on Dec 23, 2014
wisiny.com
AOC Master
Level 3:
Renaissance:
Answers
848
Questions
0
Helped
454079
Points
4753
My aoc model 729 lcd monitor displays windows start up but then says there is no signal.? This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:[email protected],we sincerely hope we can help you!
you can also check this boards whether suit you:
715L1103 AOC IDPC7425A3 Power Supply for TFT1780PSA LM729
Anonymous
Level 1:
Problem Solver:
  • Contributor 12 Answers
  • Posted on Jan 22, 2010
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
12
Questions
0
Helped
1639
Points
24
Your resolution is too high or too low try changing it.
2answers
My aoc LCD secret monitor displayed no signal when PC is run and cable is connected.any ideas?i tested my PC on other monitor it's OK.
A loose connection between your monitor and your PC will trigger the monitor no signal issue. If you're seeing the no signal message on your screen when your Windows system is running, the first thing you should check is whether your compatible video cable is firmly connected or not
How to set up aoc lcd monitor
Plug in the power and connect the display cable to your computer
AOC monitor too bright!!!
Sounds like its T'Con board fault. If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD is given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Aoc e2243fw no signal
check for loose contact at the VGA port or replace VGA cable. if won't work, check for bad component parts at the lcd controller board like open resistance or replace the board will solved the problem.
Screen+ application that came with my AOC monitor isnt working when I try to change the configuration to multiple on display 1 or display 2. What happens is "AOC grid screen executable file has...
This sounds like a computer problem and not really a television problem. Check your driver files.
Try removing your driver files. Then disconnect your AOC monitor. Reboot the computer and login. Shut down the computer and reconnect the AOC monitor. Start the computer. Now install the monitor drivers.
I have aoc lcd monitor, but no display and always orange the swicth botton. what is the problem of my lcd? can you help me? thanks..
It sounds like there is no signal to the monitor. The computer you have, does it work if you hook up another monitor? Have you taken this monitor to maybe a friends house or neighbor? See if it works. If it does; there may be a problem with your computer's video. If the monitor does not work; the issue is the monitor. It will then need to be replaced.
How do u get to the menu on my aoc lcd monitor
hi
Depending on the brand and model of your monitor, there may be extra features that require special troubleshooting tips, or there may even be alternate ways of troubleshooting basic problems. For this reason, it is important to keep your user manual.
If you have come across an issue with your LCD monitor that cannot be corrected through the basic settings, you should consult the user manual to determine troubleshooting solutions for your specific monitor.
For example, The AOC 175F LCD monitor features a 90-degree rotating display, which, in order to rotate correctly within Windows XP, must have AOC's third-party software installed. This is not something required of all LCD monitors, as not all LCD monitors offer a rotating display.
If the troubleshooting section of your user manual still does not solve the problem, it may be necessary to contact the manufacturer's support team (via phone or web) to discuss what is wrong with your monitor
1helpful
My aoc lcd monitor appear full white screen
Most probably failure in the LCD controller IC in the lcd controller board. that no signal was sent out to the lcd driver ic thus you could only see white display on the screen. A replacement of LCD panel might be the solution. regards
1helpful
2answers
Aoc lm725 display off after few seconds
I've had a very similar issue on many Dell Monitors. Mine have been under warranty and they usually send me a new monitor, but I believe the issue lies with the power supply within the monitor.
Top AOC Computers & Internet Experts
ADMIN Andrew
ADMIN Andrew
Aron
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
