The print head is not moving freely.
The print head wiper may be tacked to the print head, or the print head block may be filled with ink causing the print head not to pivot.
Kelly, error 0x97 This specific error pertains to a scanner pcb fault.
they say it has to be fixed by Epson (go figure.)
Links below may help. to show your appreciation press the helpful button and follow me on fixya for more tips and info. How to fix an Error message on an Epson Printer
If you are using a Xerox printer, you might have faced a system error problem, similar to "System error 09.038.46:113334" or something within that line.
I faced a similar error message like this a few months ago and i solved it using the following steps.
The ink count sensor flags were stuck. Verify that the ink is correct and genuine and then reset the system and error message by performing the following steps:
1- Turn on the printer 2- Wait for the xerox logo to begin moving across the display 3- Before the logo is centered on the display (stops moving) press and hold the "back" and "help" buttons on the control panel. 4- Hold both buttons until the display reads "beginning service mode initialization".Release the buttons and the printer reboots into service mode with the "Service Diagnostics" menu displayed 5- Then scroll until you find function menu then click "OK" 6- Scroll until you find "Clear ISC" fault and press "OK" 7- Click back several times and then reboot the machine.
If you follow these exact steps your problem should be solved.
B0605 message. Follow HP's directions at http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c01687323&lang=en&cc=us&conte...
and put the printer in BootCode mode then ran the firmware updater.
The directions indicated that the printer would restart on it's own, but if does not, so let the printer sit for about a minute after the Firmware Updater says it was done, then power down the printer and pull out it's power cord. Let it sit for about 15 seconds, then plug it back in and start it up. When the printer starts up, the printer's display may go through a bunch of messages (Erasing...) for a few seconds. When it finishes with all of the messages, you should be able to print to the printer again.
I hope this helps. Regards, Mike
That is either a laser scanner error or a memory malfunction. If you hear noise from the laser when it starts to print, then the laser bearings are dry. You have to carefully remove the laser assembly and add a few drops of oil to the bearings, a new laser will be best.
The error 1203 error message on the operator panel could indicate a problem with one of the ink cartridges. Please follow the steps given below:
1. Please make sure the All-In-One is powered on.
2. Pull the control panel towards you, and then open the cartridge access door. The print cartridge carrier moves and stops at the loading position.
3. Pull the old cartridges towards you, and then lift them out.
4. With the cartridges out of the printer, shut the access door and the control panel.
5. Power the printer OFF and then back ON.
6. Please check the operator panel to see if the same error has returned or if a new message has appeared.
7. If the message displayed is 1203, there is something wrong with the printer hardware.
If the message now displaying is Cartridge Missing, do the following:
1. Reinstall the cartridges into the printer.
2. Insert the color cartridge in the left carrier. Insert the black cartridge in the right carrier.
3. Push back firmly on the cartridges until they snap securely into place.
4. Close the cartridge access door, and then close the control panel.
5. If the 1203 message is still present on the operator panel, you need to insert one cartridge at a time to determine which cartridge is producing the failure.
6. With one cartridge in the carrier, close the access door and control panel.
7. Please check the operator panel. If the 1203 error is displayed, this cartridge is the defective item. If the Cartridge Missing message is displayed, the second cartridge is producing the failure.
8. Please replace the defective cartridge.
The following error message appears on the color graphics display after you insert a cartridge: Remove and Check Print Cartridges . The printer will not print. The message does not specify which cartridge has caused the error.
Solution
This error message indicates that the printer cannot determine which cartridge is causing the error. Follow the steps below to solve the problem.
Remove the color cartridge from the left stall (which has a blue latch) and refasten the latch. Leave the other cartridge in place.
Close the printer, wait 10 to 15 seconds, then look at the LCD display.
If the LCD display reads Insert Color Cartridge in Left Stall , the color cartridge may be causing the problem. Follow the steps below:
Clean the color cartridge contacts.
Reinsert the color cartridge into the carriage and close the blue latch.
Close the printer and wait 10 to 15 seconds.
If the LCD display reads Remove and Check Print Cartridges , replace the color cartridge.
OR
If the LCD display reads Remove and Check Print Cartridges , follow the steps below:
Reinsert the color cartridge.
Remove the black or photo cartridge, depending on which one is installed in the right stall. The right stall has the gray latch. Be sure to refasten the latch on the empty stall.
Clean the black or photo cartridge contacts.
Reinsert the black or photo cartridge.
If the LCD display reads Remove and Check Print Cartridges , replace the black or photo cartridge.
Remove and then reinsert the cartridge indicated in the error message.
If the error is still displayed, clean the contacts.
If the error message is Error. Remove and Check Black or Photo Cartridge , the following steps may help:
Remove both cartridges, lower the latches, and close the printer access door.
Turn off the unit by pressing the On button on the front panel. Wait for the printer to completely shut down.
Turn the printer back on by pressing the On button.
When the message display reads Insert Print Cartridges , open the access door and replace the cartridges.
If neither of the steps above fixed the problem, either the cartridge or the printer is faulty
