Electronics - Others Logo
Posted on Jan 19, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My skymedi 8GB write protect, - Kingston Electronics - Others
laikexpert
Level 3:
President:
  • Master 281 Answers
  • Posted on Feb 04, 2010
laikexpert
Master
Level 3:
President:
Answers
281
Questions
0
Helped
272343
Points
1232
LLFTOOL is a utility for low-level disk drive formatting,
also supports formatting of FLASH cards using a card-reader.
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Skymedi usb 8gb media write protected
If the write protec switch is in the on position on the card or usb, turn it to off. If it still says its locked, its history!
Remove write protection on 8gb sdhc card
SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Drive write protected
Try opening them in a different program I'm pretty sure Write Protected just means you can't edit them
1helpful
2answers
MY 8GB SANDISK CRUZER BLADE PENDRIVE NOW SHOWS WRITE PROTECTED...PLEASE HELP IF U CAN........
My 8 Gb pen drive now right protected how can i remove the write protection pls.....................Pls..............say the solution
1helpful
My usb (kingstone skymedi 8gb) driver is reading as 0bytes capacity
Format it by going to the Explorer and right clicking then click "Format", press format on the prompt and wait for it to finish.
Have fun :)
4helpful
2answers
My 8gb kingston usb falsh automatically canged to skymedi and also not formated ,no copy , write protected error , plz help me wht to do ????
no need to worry friend first you need to active the usb port and then fix the pendrive to usb
follow bellow steps
---> ctrl+R
----> in this tyoe " cmd "
-----> in command prompt type usb drive name
examle : if drve is H then type like H:/ or F:/ etc
----> format H: or format F:
-----> if any question ask then u aswer yes press "Y"
----.> your problem is solve
in case failure then you can try this another operating system or another computer
16helpful
2answers
Kingston DT 101 II Usb Device become SKYMEDI USB drive
http://dl.dropbox.com/u/4040651/HPUSBFW.EXE
2. Format
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
5helpful
3answers
Skymedi USB drive is not recognised on my computer
i have usb kingston 4 GB data mini traveler, and my problem usb detect skymidi usb drive i dont know skymedi. i don't want if have format,because there are many data which is of important.
how is it's solution.
thanks 4 all
by blurz
3helpful
I can't format my 512MB kingston data traveler
Dude I just fixed mine running the SKYMEDI tool version SK6211BA_20080917 on my 8GB kingston datatraveler 100 is hard to get it but you will find it, you need to determine what version of the sw applies to your flash drive, check the SKYMEDI website www.skymedi.com.tw
Top Kingston Electronics - Others Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you a Kingston Electronics - Other Expert? Answer questions, earn points and help others
