A few important bits of information about using faults and fixes on usb drives
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts click start control panel administrive tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in one box then select check now start or you might tick one box then return after its finished the first repair then return and tick the second box (I have found better results ticking the first box then reurn and tick the second box) you should not do anything while the chkdsk utility is in progress any input may damage this drive also you might need to do this
click start click to open on my computer you should see your usb drive F: right click select properties there will be an array of options select the sharing tab option then advanced sharing
permissions make sure you have a tick in the share this folder box then click permissions make sure all three boxes are ticked you full control change and read in windows 7
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XPalsoIf you are running a Windows XP OS then you might be able to: click start right click on my computer select open
Right click the icon of your Flash Drive (It should be F: / E: or something) Click Properties in the menu that comes up Click the Sharing tab Click permissions And finally, click Allow next to Full Control.
if you need more help with this post a reply http://majorgeeks.com/Dr._Freeware_System_Utilities_d6416.htmlSupport IDE/SATA/USB Hard Drives memory cards USB Memory Drives Windows Password Cleaner Available in Live CD to run offline This is a utility to blank the password of any user that has a valid local account on your Windows system. You do not need to know the old password to blank the password. hope this helps
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts if now you can see your usb drive there might not be any need to do the following click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive I found that you get best results by ticking one box then returning after it has finished then tick the other box then you might have restore it to its default status
Right click on usb drive select properties you will have an array of options
Select the hardware option then select your drive properties policies
restore defaults
In XP
Right click on your drive select properties then on customize restore Default in W 7 or if it has a password http://majorgeeks.com/Dr._Freeware_System_Utilities_d6416.html Support IDE/SATA/USB Hard Drives memory cards USB Memory Drives Windows Password Cleaner Available in Live CD to run offline This is a utility to blank the password of any user that has a valid local account on your Windows system. You do not need to know the old password to blank the password. hope this helps
im not sure i understand the problem there is some software you can download http://majorgeeks.com/Dr._Freeware_System_Utilities_d6416.html Dr.Freeware System Utilities which includes data recovery software, data backup, password reset tools for Windows helps you to maintain your system. Dr.Freeware is freeware, you can download and use it for free. Support IDE/SATA/USB Hard Drives, memory cards, USB Memory Drives Windows Password Cleaner Available in Live CD to run offline This is a utility to blank the password of any user that has a valid (local) account on your Windows system. You do not need to know the old password to blank the password. Support Windows NT/2k/XP/Vista Support IDE/SATA/USB Hard Drives
if i have missed the problem post a replyHope this helps
((computer administrator for sharing))
You will have to be the computer administrator to change any values on any hard drive
click start control panel user accounts you should see a box with the administrator and the guest account if you have made one click on the administrator this may vary depending on which operating system you have
click start click to open on my computer you should see your hard drive usually C: right click select properties there will be an array of options select the security tab option then advanced make sure you have full control in windows 7
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP alsoIf you are running a Windows XP OS then you might be able to: - click start right click on my computer select open- Right click the icon of your Flash Drive (It should be F:/ or something) - Click Properties in the menu that comes up - Click the Sharing tab - Click permissions - And finally, click Allow next to Full Control. also you might click start control panel file and folder option view place a tick in show hidden files and folders and drives hope this helps
im not sure what you wat to do or are referring to if you are try to remove the password download dr freeware i have never used or had to use it it reads like it can remove passwords from any usb drives and if you are trying to use it but dont the basics
insert this drive into a
usb slot
click start click on my
computer you should see your usb drive or
click start all programs
accessories open windows explorer navigate to your usb memory stick then go to
the information you want to back up select the information right
click select copy then back to memory stick select then right
click select paste
or select the imformation
hold the cursor on then drag it to the memory stick and drop it into it
or select the
imformation right click and send to the memory stick
http://majorgeeks.com/Dr._Freeware_System_Utilities_d6416.html Dr.Freeware System Utilities which includes data recovery software, data backup, password reset tools for Windows helps you to maintain your system. Dr.Freeware is freeware, you can download and use it for free. Data Recovery/Data Backup: Supports Logical scan and Raw scan, Supports NTFS, FAT, UFS 1, UFS 2, EXT2FS, EXT3FS, and ISO 9660 file sytem, Supports IDE/SATA/USB Hard Drives. Data Recovery - Recover your lost data Available in Live CD to run offline Recover accidentally deleted files in your hard drive Recover data from RAW Drive(partition table or file system is damaged) Support NTFS, FAT, UFS 1, UFS 2, EXT2FS, EXT3FS, and ISO 9660 Support IDE/SATA/USB Hard Drives, memory cards, "USB Memory Drives" Drive Dumper - Backup your hard drive Available in Live CD to run offline Available to run on Windows Support Windows 2K / XP / 2003 / Vista / 7 (Windows Editition) For data rescue, backup, migration, or computer forensics etc. Transfer important important data from damaged Drive(partition table or file system is damaged, has lots of bad data blocks) Support NTFS, FAT, UFS 1, UFS 2, EXT2FS, EXT3FS, and ISO 9660 Support IDE/SATA/USB Hard Drives, memory cards, "USB Memory Drives" Windows Password Cleaner Available in Live CD to run offline This is a utility to blank the password of any user that has a valid (local) account on your Windows system. You do not need to know the old password to blank the password. Support Windows NT/2k/XP/Vista Support IDE/SATA/USB Hard Drives
Hope this helps you
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you should see a yellow question mark?
ports(com&lpt)right click update driver if this fails to fix the problem
click start control panel administrive tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start or you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
click start click on my computer you should see your usb drive right click select properties you will see how many mbs are used and how many free mbs are available
hope this helps
USB drives can be write-protected by modifying the StoreageDevicePolicies Registry key and WriteProtect Registry value.
click Start>run>regedit to open Registry Editor. and press control+F to open the find dialogue box and type "usb device" or "driverdesc" to open usb mass storage device or type "usb mass storage device" in the search windows. And right click on it and delete. This will set the policy value to 0. then insert your usb device. It will work fine.
# Remember: do not delete any unknow files in the registry as this will make some programes not work as usual.
alsoIf you are running a Windows XP OS then you might be able to: - click start right click on my computer select open- Right click the icon of your Flash Drive (It should be F:/ or something) - Click Properties in the menu that comes up - Click the Sharing tab - Click permissions - And finally, click Allow next to Full Control. also you might click start control panel administrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question mark? right click to reinstall drivers or if you can see your usb drive but its not working ports(com&lpt)right click update driver check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts also scroll to disk drives if you can see your drive + to expand right click you should see options to update driver,disable,uninstall scan for hardware changes. or select properties you should see options in the general tab to troubleshoot,policies,volumes,driver and details under the driver tab you will have the options to check the driver details,update driver,rollback driver or uninstall hope this helps
43 questions posted
15 Questions
2 Questions
