Nintendo Wii Fit - Balance Board + Game Console Logo
Posted on Jan 17, 2010
I've had the Wii fit two days the second day I did the body test it tells me I have put on 6lb in one day I'm sure this isn't right!
Anonymous
Level 1:
Scholar:
  • Contributor 54 Answers
  • Posted on Jan 18, 2010
Anonymous
Contributor
Level 1:
Scholar:
Answers
54
Questions
0
Helped
10272
Points
94
Heavier clothes, time of day, time and heaviness of last meal makes a difference. Even the last time you took a potty break last time and this time can make a difference.
If you retake it test and it consistently measures about the same then I'd suggest it is correct. It would be best to make sure your diet, time of day, and clothing is fairly consistent from day to day. Generally, you'll weight lighter at later in the night. Especially if you eat an early meal and take a visit to the restroom.
Probably not the answer you were looking for but I hope this helps!
Change old internet code and put in a new one.
You do it the same way as you would when you put the code in the first time.
From the wii home menu...
Go to Wii Options in the lower left.
Click on Wii Settings to the right.
From this first list, click the right arrow.
Now on page 2, click on Internet.
Then click Connection Settings.
From this list, click Connection 1.
Then, click Wireless Connection...
and then click Search for an Access Point.
It will briefly search for any access points and when this screen comes up, click OK.
The following will be a list of nearby access points. If the one you are looking for doesn't show up, click Try again. Then, click the one you have access to...
Enter in the router password
click OK...
and OK again.
It will test the connection...
And if successful, the following will drop down. Click Yes to update Wii.
Sometimes the above screen is false, saying there is an update when there isn't and the following will appear...
Now, back in Wii System Settings, click on WiiConnect24.
From the following list click WiiConnect24.
Click On and then Confirm to save your settings. This feature allows for updates to be seemlessly sent to your Wii so you don't have to do the final step every time.
Ok, the final step, just as a way to make sure your Wii is up to date. Click the right arrow from the 2nd page of Wii System Settings.
Click Wii System Update...
click yes...
it will test your connection for a few seconds...
an update screen may quickly come up and tell you there is an update (whether or not your Wii actually needs one)
and the following screen will appear. Click Wii Menu to finish.
Delete an old internet number and put in a new number
click OK...
and OK again.
click yes...
I am trying to put Internet on my wii. How can I get it to pick up my wifi
When the following screen appears, click OK...
and OK again.
click yes...
I press start on zumba for the wii and nothing happens just a blank screen ?
Hi! First, make sure that you put the CD in the WII Console the right way. If it is ok, turn off the WII Console for about 2-3 mins. and afterwards, turn it back on.
I hope this will help you! Have a nice day! :)
2answers
I what to know how to put internet on my wii
and OK again.
click yes...
Disc doesn't work when I change from body test to training on Wii
Wii Fit? The problem can be that your Wii is modded (IF ITS MODDED), or that the disc contains scratches.
I keep getting the message to "step off and press A" for the body test.
You need to step off the pad, wait until it tells you to step on. Then you push A to conduct the body test. If your pad is turned off push the button on the front of the wii fit pad then repeat the first steps i described.
1helpful
I'm trying to go through the setup to WII fit. My child did the body test with no problems a couple of days ago. I keep getting an error (fidgeting) when I try to take the body test. Tried to do fit test...
If your Wii Fit Balance Board is on carpet, be sure to use the extra foot pads that came with your board. If your carpet is really thick, you may need to use a flat woodend board to set the balance board on.
Finally, make sure that you are NOT using your child's Miii to do your own balance test. Each user of Wii Fit must use their own Mii character.
If you don't like my suggestion, please don't rate this suggestion a '1'. If my suggestion doesn't help, the problem may exceed the scope of what can be answered here. You will need to contact Nintendo directly through their website and open a problem ticket.
Good Luck!
1helpful
Wii Fit- Editing the time of day
The FIT gets its time from the console. Go to the WII settings screen and update the date/time there.
Top Nintendo Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Aron
Sean Wright
Sean Wright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
