Sanyo Xacti VPC-HD2000 High Definition Camcorder Logo
Posted on Jan 14, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Short battery life when idle - Sanyo Xacti VPC-HD2000
The battery life on my Sanyo Xacti VPC-HD2000 when in an idle state (i.e. fully turned off) is extremly short, only aroung 3 days.
I have also tried a different battery which is compatible with my camcorder and the idle battery life is still short, so I think a faulty battery can be ruled out.
Regards
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Apr 22, 2010
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
503
Points
Strange, mine lasts a very very very long time, but in a standby state (power on, just close the lcd lid). Have you tried to just keep it in the standby state? I will never turn it off unless I need to, like to change sd cards, because it is super quick to capture video and it does not kill the battery.
I have 2 of these dual cameras and John is quite right, the Sanyo HD2000 is not a "normal" camera, its quite abnormally exceptional and way ahead of its time! Having a f1.8 lens, 1/2.5" cmos, 1080p @ 60 FRAMES/second, really makes it not "Normal". You will need a better computer to process the crazy 1080p/60fps images.
timtak
Level 1:
  • Contributor 23 Answers
  • Posted on May 08, 2013
timtak
Contributor
Level 1:
Answers
23
Questions
Helped
98851
Points
31
Three years later and it is still an exceptional camera. Mine lasts for about a month on standby. Batteries do die though. They can be bought cheaply online.
Anonymous
Level 2:
New Friend:
  • Expert 76 Answers
  • Posted on Jan 14, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
76
Questions
Helped
11798
Points
211
Those types of cameras are no more really used... it is good to get a just normal cannon or sony camera... and you will be able to do wonders
The camera always forgets the date and time and I have to do it again and again at every switch on. Maybe it is a battery problem? Could you help us please ?
Mine does that if I do not get to the end of the set up process but if I finish set up, setting at least the date and time then (as you say, as long as the battery holds a bit of power) it will stop asking me.
I have a Sanyo Xacti VPC-E60 EX Digital Camera.
If the recharageable battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Firmware for sanyo e1292
I purchased (used) the exact same camcorder from eBay. It arrived. Same deal as you described - turn "ON" and white screen appears. SO, I went out and got a new battery. Charging it now, so I will let you know the result after charging. This is my LAST go around with this. Normally, I would never buy a camera from eBay, but I've bought so much other stuff I have not had an issue with (including new & used electronics.) Will keep you posted.
1helpful
I have a Sony HD2000 camcorder. When using it the other day the screen went white. On and off buttons still work but all I can see is white.
Cant find my softwear for a vpc-hd2000 was not in box..now what
Does anyone have an updated link for this? I got "NOT FOUND" etc...
1helpful
Sanyo Xacti VPC-E1W dispay is black, no image
Is the camera on and does it have batteris fully or half way charged?
1helpful
Wrong battery charger in box
Radio Shack   I have a Xacti HD2000 and it shipped with a Sanyo VAR-G9 adaptor.  The RadioShack replacement is a P/N 273-1696.
There is a switch that must be set to +5V on the unit, and you need to match the assorted tips that come with the unit to the one you need for your camera.  On my HD2000, the "+" side is on the tip, but this is on an image on the back of the AC adaptor
Look for a diagram on the back of the adaptor you have. There will be two diamond boxes  one on the left with a '-' and one on the right with a "+"   and the diamonds will be connected to semi circles. The inside semicircle is the "Tip".
In my case (Sanyo Xacti HD2000)the "+" is connected to the dot in the center, so I have to align the "+" symbol with the word "tip" on the end of the Radio Shack cable.
(If this gets plugged in backwards... you can fry the camera).
Hopefully someone at Radio Shack can help you set this up properly.  That way you don't have to mail-order and wait long.
2answers
Sanyo camera shuts down and won't power up
I connected my Sanyo VPC - 603 digital camera to an AC/DC adaptor due to battery malfunctions. After about 5 seconds, i heard a spark sound and the camera went off. What might have gone wrong? How can it be repaired?
Top Sanyo Video Cameras Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Sanyo Video Camera Expert? Answer questions, earn points and help others
