UV100E Ultraiolet system. Noticedbulb not coming on. LED indicator is off. WHen I press the reset button for 1 sec, green lightcomes on for ~1sec, then off. Bulb "looks" fine - both filaments appear to be intact. I do not think the installer cnnect it to the enviracaire elite RF system whwn intalled 2 years ago.
*Plug in air cleaner and press POWER button until short “beep” sounds. . Press the RESET FILTER button by gently inserting a paperclip into the RESET FILTER hole on the control panel. The light will flash 5 times before a “beep” sounds to indicate the filter has been reset.
I have the same unit.
Have you cleaned out the removable filters?
also the red light at the bottom indicates the time to clean the filters.
to reset it, use a paper clip. The red light on the bottom right is the filter indicator light, what looks like it should be a light beside that filter light, is actually a reset button, just poke it with a paper clip for a few seconds to reset. The bottom red light goes out
Filter Replacement Filter Replacement Indicator: Your Defender® is equipped with a Filter Replacement Indicator located on the front panel. Anytime this red indicator flashes, it is recommended that you call your authorized FILTERQUEEN® Distributor to order a replacement filter. Anytime this red indicator stops flashing and remains solidly illuminated, it is recommended that you change your filter. To receive full benefit from your Defender® and to extend your warranty, it is strongly recommended that you follow the filter replacement schedule suggested above. Under higher pollution levels, your filters will need to be replaced more frequently. The Filter Replacement Indicator is operated by filter time in use and is controlled by an onboard timer. After 11 months of time in use of your Medi-Filter® Cartridge, the Filter Replacement Indicator will begin to flash. It will continue to flash until the you reach 12 months of time in use, at which time the Filter Replacement Indicator will stop flashing and remain solidly illuminated. After replacement of your Medi-Filter® Cartridge, you must reset the Filter Replacement Indicator's timer. When the timer has been properly reset, the Filter Replacement Indicator will turn off. Resetting the Filter Replacement Indicator Timer: After replacement of your Medi-Filter® Cartridge per the instructions found on page 7, the Filter Replacement Indicator's timer can be reset by performing the following sequence of steps: 1Plug unit into outlet. 2Press power On/Off switch to the On ("I") position. 3Allow unit to start running at low speed. 4PRESS and HOLD both the Up and Down arrow buttons until the Filter Replacement Indicator starts to blink. 5 Release both the Up and Down arrow buttons. 6 While the Filter Replacement Indicator is still flashing*, again PRESS and HOLD both the Up and Down arrow buttons until the Filter Replacement Indicator turns off. If the steps above have been performed properly, the Filter Replacement Indicator will turn off and not flash again for 11 months. If the Filter Replacement Indicator remains on, repeat the steps again. *Note that in step 6 above, the Filter Replacement Indicator MUST still be flashing when the buttons are pressed the second time. The Filter Replacement Indicator will continue to flash for approximately 3 seconds after the buttons are released as required in step 5 above. Note: Under higher pollution levels, your filters will need to be replaced more frequently. Note: To order replacement filters, call your authorized FILTERQUEEN® Distributor, or call 1-440-846-7800 for the Distributor nearest you.
1. Plug unit into outlet.
2. Press power ON/OFF switch to the ON position.
3. Allow unit to start running at low speed.
4. PRESS and HOLD both the UP and DOWN arrow buttons until the FILTER REPLACEMENT INDICATOR starts to blink.
5. Release both the UP and DOWN arrow buttons.
6. While the FILTER REPLACEMENT INDICATOR is still flashing, again PRESS and HOLD both the UP and DOWN arrow buttons untile the FILTER REPLACEMENT INDICATOR turns off.
If the steps above have been performed properly, the Filter Replacement Indicator will turn offand not flash again for 11 months. If the Filter Replacement Indicator remains on, repeat the steps again.
*Note that in step 6 above, the Filter Replacement Indicator MUST still be flashing when the buttons are pressed the second time.The Filter Replacement Indicator will continue to flash for approximately 3 seconds after the buttons are released as required in step 5 above.
It won't go out by itself.
So after you have replaced the V5 Cell Filter in the IQ Air, here are the steps you'll need to follow in order to reset the filter indicators:
At the main menu on the control panel, push the menu button 7 times until you get to the screen that says Replace Filter.
At the Replace Filter screen, press and hold the Enter Key until the cursor appears, and is flashing.
Press the UP arrow button on the keypad until you get to the V5 Cell Filter.
At the V5 Cell Filter screen press the Enter Key to confirm your filter reset selection. This will turn the corresponding filter LED to a flashing red light. IQAir requires that your reconfirm the filter selection to prevent inadvertently resetting the wrong filter. If you chose the wrong filter, press the menu key after pressing the enter the first time to disregard the filter change command.
To confirm the filter reset selection, press enter a second time, which will reset the filter life, and reset the filter hours.
You can repeat these instructions for the other two filters on your machine when it's time. Here's a link to the product manual for your IQ Air Health Pro Plus which will give you the same instructions, as well as other maintenance instructions.
I hope that this information was helpful to you. If you were able to reset your filter, please be kind and rate the repair as helpful by clicking the thumbs up icons in the top of my repair. This is what really keeps Fixya experts continue leaving free repair solutions. Thank you very much,
I have a Bionaire tower air filter model BAP1700 that I bought from Costco. The filter check LED came on recently after 5 months of use. After cleaning the Permatech filters, I tried every remedy on this website including following the instructions that say push power button for 2 secs. Nothing worked. Then I noticed a tiny hole on the control panel in front of clean filter LED; I pushed a paper clip pin into that hole, felt a click, held it down and 2 secs later, LED went out. Success!
When the red light is blinking, press and hold both up and down arrows until the red light blinks RAPIDLY, release both for a second or two, and press and hold both again until it stops blinking. It cured my problem.
