It's most likely the lamp is bad or the part that starts the lamp called a ballast is bad. The LP540 model has an issue with the ballast burning out. The ballast is a part that starts or strikes the lamp. The only sure way to test is to try starting it with a known good lamp.
You can check for signs of a bad lamp. Think about how long you've had your projector & estimate the total hours on your lamp. If it's over 500 it very well could be the lamp as they fail at any time. Remove the lamp cover door & pull out the lamp to visually inspect it. Look in good light & use a magnifier if available too check for any cracks or chips in the small bulb & look to see if the round part of the small bulb is covered with a lot of white or if it's not round anymore. If it's very white it means it has a lot of hours on it. If there's any loose glass inside (check by turning the lamp cage in different directions) then the lamp is bad. If it's nice & clear or has only a small white spot it's probably a good lamp.
I repair almost all Infocus models if you need a quote.
Thanks & good luck,
Jim
InFocus made several firmware (and hardware) updates to fix their lamp problems. Check their support and update your fw if it hasn't been made. Of course you need to get it started to see what fw version it is running, Here is a link that might help you.
http://www.infocus.com/projectors/LP540#support
