2004 Dodge Stratus Logo
Posted on Jan 13, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Windshield washer does not work - 2004 Dodge Stratus
Anonymous
Level 3:
  • Master 593 Answers
  • Posted on Jan 13, 2010
Anonymous
Master
Level 3:
Answers
593
Questions
0
Helped
332709
Points
2054
Hi
your 1st step is to have someone push the wash button while you listen
at washer res.(eng. off key in on pos.) to see if you can hear the pump
engage if not we move to step 2 check fuse if thats good onto step 3
the pump itself is inside the washer res. locate the plug at bottom of res. remove the elec plug + use a test light to test for power if it lights up change the lights ground(the clip end) from eng. or wherever it is to
the 2nd wire on the plug (by the way have someone in car to push
button while testing) if it lights up again you got bad pump.
if no power on 1st wire you test problem may be the switch.
if the test light don't come on at the 2nd wire check your ground
give this a try hope it works for ya any other ? give a shout good luck
Windshield wipers on a Chevy 2005 trailblazer only works on high
Do you know how to test automotive electrical circuit's using a DVOM - digital volt ohmmeter ? Do you know what a wiring diagram is an how to read one ? Free wiring diagrams here http://www.bbbind.com/free-tsb Enter vehicle info. year , make , model an engine size. Under system click on body & accessories ,then under subsystem click on wiper/ washer's . Click the search button then the blue link.
Windshield Wiper/Washer System Components
The windshield wiper/washer system consists of the following components:
• Windshield wiper/washer switch
• Windshield wiper motor
• Windshield washer pump
• Windshield washer relay
• Outside moisture sensor
• FRT WIPER 25A fuse
• W/S WASH 15A fuse
Windshield Wiper/Washer System Operation
Accessory voltage and ground is supplied to the windshield wiper motor and provides the power for operating the wiper motor and logic power to the wiper motor module. The WASH, MIST, LOW, and DELAY modes are controlled by the windshield wiper/washer switch through a series of internal resistors. The windshield wiper switch supply voltage circuit is a 12-volt reference from the wiper motor module to the wiper/washer switch, and the switch position determines the point on the resistor assembly where the reference voltage is applied. The windshield wiper switch signal 1 circuit supplies the voltage from the resistor assembly to the wiper motor module and the signal voltage determines the operating mode. High speed operation is controlled by the windshield wiper/washer switch through the windshield wiper switch high signal circuit. The windshield wiper switch high signal circuit is supplied 12 volts by the wiper motor module and when the wiper/washer switch is turned to the HIGH position the windshield wiper switch high signal circuit is grounded through the switch ground circuit. The windshield washer pump is controlled through the windshield wash relay. The windshield wash relay coil and switch is supplied battery positive voltage, and during WASH mode the wiper motor module grounds the washer relay control circuit energizing the relay. When the relay is energized battery positive voltage to the switch side of the relay is supplied to the washer pump control circuit.
Where is fuse for 1997 mercury wagon for windshield wipers
1997 mercury wagon ? Sable ? VISUAL INSPECTION CHART-WINDSHIELD WIPER AND WASHER SYSTEMS Mechanical Electrical
  • Windshield wiper blade missing or damaged.
  • Binding windshield wiper pivot arm.
  • Binding windshield wiper mounting arm and pivot shaft.
  • Empty windshield washer reservoir.
  • Kinked or broken windshield washer hoses.
  • Open fuse junction panel Fuses:
    • 8 (5A)
    • 12 (5A)
    • 20 (5A)
    • 23 (5A)
  • Damaged windshield wiper motor.
  • Damaged windshield washer pump.
  • Open connectors.
  • Corroded connectors.
  • Inoperative multi-function switch.
  • Open thermal breaker internal to the wiper motor
Which are not working , front , back or all ?
I/P Fuse Panel C225
Under left corner of instrument cluster
Where is the windshield washer motor fuse located ?
images for 2009 Nissan Rogue SL Where is the
Windshield Wiper Pump - Not working - Nissan Forum ' Nissan Forums
forums.nicoclub.com/windshield-wiper-pump-not-working-t581434.html
Oct 22, 2013 - Year of vehicle -- 2011 Nissan Rogue SL Leather/Nav Package ... rather an engineer and found that my windshield washer pump was not ... sprocket: Posts: 150: Joined: Thu Jun 11, 2009 1:27 pm: Location: Metro Detroit, MI ... windshield washer fluid switch backwards ?
Apr 27, 2012
Windshield WASHFLUID ISSUE!
Dec 11, 2009
Front windshield sprayers not working..AHH!!!
Nov 10, 2009
More results from forums.nicoclub.com
1helpful
2answers
My windshield wipers don't work
To troubleshoot car windshield wiper problems, you need to thoroughly investigate problems with any of its operating parts. Here are some of the things that you need to check to determine why are your car windshield wipers not working.
Check Wiper Motor
The wiper motor is the driving force of the windshield wiper. Feel the motor and listen to a humming sound. If there is no humming, the motor is the problem. Check if the motor is working properly and see to it that its electrical connections are made properly. If you find that the motor is dead and beyond repair, get it replaced immediately.
Check For Break in Connecting Wires
The connecting wires of the motor sometimes go loose and that may cause the windshield wipers to stop working. Also check the battery plug connection which the motor has. Connecting the loose wires properly or fixing/replacing the plug might solve your problem.
Check Wiper Switch
Another wiper assembly part that can malfunction is the wiper switch itself. Check for switch malfunction and if you find that is indeed the problem, get it replaced from a mechanic.
Check for Bent Wiper Arms
Bent wiper arms can cause the operation of the wipers to be hampered. If the wiper arms are bent beyond repair, get them replaced immediately.
Check For Blown Out Car Fuse
A blown up car fuse could be the culprit that has stopped the windshield wipers from working. Check the fuse assembly under the dashboard of the car. Replacing a blown fuse might fix the problem of windshield wipers not working.
Windshield Wiper Sprayers Not Working - Things to Check
Sometimes the windshield wiper sprayer stops working which can be very annoying. The washer mechanism is a self cleaning mechanism for the windshield. Here are some of the things that you need to check in case it is not working.
Check Windshield Washer Motor
The windshield washer mechanism might have been impaired due to the malfunctioning of the wiper washer motor. Check if its working and get it replaced if it is beyond repair.
Check Windshield Washer Fluid Level
Sometimes the washer doesn't work because the washer fluid levels are not filled to requisite levels. Filling in fluid might restore normal functioning.
Check For Broken Washer Hose
The connecting washer hose that connects the reservoir to the nozzle, might be broken or worn out stalling the overall operation. Check the hose for leaks and get it replaced.
Check Washer Nozzle For Clogging
Last thing to check is the nozzle of the washer for clogging. An obstruction in the washer nozzle might be the reason for windshield wiper sprayers not working. Using a pin, clean the clogged nozzle. This might restore the sprayer to the normal working condition.
Winshield wipers dont work
Check Wiper Motor
Check Wiper Switch
1helpful
My widshield wipers dont work and the fuses are fine
Check Wiper Motor
Check Wiper Switch
4helpful
2answers
My wippers stoped working on my way home
Check Wiper Motor
Check Wiper Switch
Wipers don't work on my 2006 Colorado. They drag and sometimes don't come on at all
Windshield Wipers Not Working - Things to Check
Check Wiper Motor
Check Wiper Switch
2helpful
Mercury villager 1994 washer pump not working
the pump motor likely is bad. get a used washer fluid reservoir at a pick n pull yourself or at car-part.com. page with * is lowest cost.
Pump and Reservoir, Windshield Washer Removal
  1. Disconnect the battery ground cable (14301).
  2. Raise and support the vehicle.
  3. Remove the RH wheel (1007).
  4. Remove the RH front fender splash shield (16103). Refer to Section 01-02 for the removal procedure.
  5. Remove the windshield washer reservoir top bolt.
  6. Disconnect the windshield washer reservoir fluid level sensor electrical connector.
  7. Disconnect the rear window washer pump electrical connector from the rear window washer pump.
  8. Disconnect the windshield washer pump electrical connector from the windshield washer pump (17664).
  9. Place a suitable drain pan under the windshield washer reservoir (17618) and drain the washer fluid.
  10. NOTE: The rear window washer hose end is color-coded, matching the connector on the rear window washer pump. Match the colors to ensure proper installation.
    Disconnect the washer hoses from the windshield washer pump and the rear window washer pump on the windshield washer reservoir.
  11. Loosen the two windshield washer reservoir side bolts.
  12. Remove the windshield washer reservoir by sliding it out of the side slots.
  13. Remove the windshield washer pump.
    Installation
To install, reverse the removal procedure. Tighten the lug nuts (1012) to 98-118 Nm (72-87 lb-ft).
Top Dodge Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Dodge Expert? Answer questions, earn points and help others
