2002 Kia Sedona Logo
Posted on Jan 10, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My kia sedona van only heats up for a minute or
My kia sedona van blows hot air from the heater for a minute or two then blows cold air
Anonymous
Level 2:
New Friend:
  • Expert 79 Answers
  • Posted on Jan 11, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
79
Questions
Helped
33174
Points
126
Check the metal part of the heater core lines at the firewall if you can get to them and see if one side is noticeable colder than the other. At least one of them should be hot or you have a bad thermostat. If both are hot than your hot/cold actuator inside is having a problem
  • Jane
    Jane Dec 01, 2013
    Where is the hot/cold actuator located?
My heat. blow cold air what is wrong with it it is a 2003 kia sedona ex
you have to bleed your cooling system with the heater on until all the air is purged out of it then it should heat up quickly.
1helpful
Where is the actuator door located?
Under the dash in the heater box.
How do I get the front heater to produce warm, hot heat from the blower? for 2003 kia sedona
If the heater hoses for the front heater are getting hot, it could be a blend door problem under the dash.
Heat and ac stopped working in 05 kia sedona
check that the heater control (tap ) is being turned on by the controls.. Have an accredited ac mechanic check the ac system .
How do you flush the front heater core in a 2005 kia sedona ex?
you need to burp the system lift vehicle so front wheels are higher then back and run vehicle with heat on and coolant resivour cap off for about 30 mins
2003 kia van rear air blowing hot
it should ony blow hot from the vent on the floor. this is controlled from a button on the dash labled RR HEATER. if the vents are blowing hot from the roof its another problem. let me know if you need more help
MY REAR HEATER IN MY 2004 KIA SEDONA IS NOT HOT
MY REAR HEATER IN MY 20304 KIA SEDONA IS NOT HOT JUST BLOWING COLD AIR ANY IDEA'S
The heating does not get warm when the car is stationery
try a new thermostat it sound like the problem.
Top Kia Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Kia Expert? Answer questions, earn points and help others
