Automatic mode (using the supplied USB cable) - Enables the headset's advanced features for the PS3. Using automatic mode, you can pair the headset with any PS3, but only the most recently paired PS3 will be saved in the headset's list of paired devices.
Bluetooth discovery mode - Sets up the headset as a standard Bluetooth headset. By using Bluetooth discovery mode you can pair the headset with many other Bluetooth devices.
On your phone, make sure bluetooth is turned on (settings, general).
While
your phone is in discovery mode, turn your bluetooth device on and put
it in discovery mode (usually you have to hold the power button for 7-10
seconds).
Your phone will find the device, and you will be
prompted to enter the devises PIN number (often 0-0-0-0). Your phone
should pair with the device then.
While
it in discovery mode ***(usually you have to hold the power button for 7-10
seconds)***
While
seconds).
On
While
seconds).
On
While
seconds).
On
While
seconds).
You need to make sure your wireless function is turned on, on your phone. Look under settings and tools go to add new device. You also need to place your headset in discovery mode. read the directions that came with the headset it will tell you how to do that.
had same problem with this headset on two phones and finally solved it.
1. make sure bluetooth on phone is activated (know that sounds silly but some people forget)
2. with the headset turned off, press and hold the on/off button on the headset until the light on the headset FLASHES CONTINUOUS BLUE AND RED (about 8 seconds). This is most important, because if lights on headset are not continuously flashing blue and red, the headset is not in discovery mode.
3. once headset is in discovery mode, go into "my devices" on bluetooth menu on phone and click to search for new devices. make sure phone and headset are close together. phone will say searching- BE PATIENT, THIS STEP TAKES THE PHONE SOME TIME. eventually phone will show that it found your headset.
4. once the phone lists the headset, click on the headset and tell the phone to connect to the device. at this point the phone will bring up a passcode screen. enter 0000, and tell it to connect. when it connects, the lights on the headset will automatically go to an intermittent blue. you should be all set.
the biggest mistakes my kids made trying to pair these headsets were:
1. failing to turn bluetooth on for the phone
2. turning the headset on in something other than discovery mode (continuous blue/red flashing lights)
3. not being patient enough to wait for the phone to find the device.
