My sump pump usually runs only two or three times a day at this time of the year. Now it is going off every 5 minutes (I timed it). The water is running in like someone turned on a faucet. I'm afraid it's going to burn out. I'm not sure of the brand or model. Where do I start to fix this?
Notting your statement that water is running in like someone turned on a faucett... Your sump pump is simply doling it's job. As the water rises it triggers the float switch / sensor and activates the pump. The pump has enough capacity to empty the catch basin to the point the float / sensor switch shut the unit off. The pump is thermally protected and will stop if there really is a problem. You home electrical circuit more than likely has either circuit breakers or fuses. From what I am reading none of those have tripped or blown. Once again the sump pump is simply working normally based out your description of the the amount of water coming in. Also not that if it did not run you would be faced with a flooding situation. Relax and enjoy your day :)
By the sounds of it, you are not in a very snowy climate in the northern hemisphere, or you are in a heat wave. the sump is used for getting rid of ground water near the footing of the walls so the soil doesn't become too loose (or wash away) and your house does not sink. right now, it sounds as if the sump pump is taking the water from the ground, pumping it back on your lawn, it soaks back into the ground in to the sump, and continues over and over. see where it's unloading. the outlet tubing should let out at least 10 feet from the house. if the hose is broken or fell off near the wall of your house, the expelled water is soaking back into the ground and right back into the sump. there may also be an underground water issue. if your water table is unusually high or there is a water main break, you'll have the same problem.
Your problem may be one of the following:
First check or just replace the fuel filter. Usually located under the car in front of the rear axle, drivers side.
Next, the fuel pump may be worn out. Usually they get loud or stop working (running).
Next, check the fuel pressure regulator. Usually located on the front fuel rail, drivers side.
Is the vacuum line attached? Not leaking or rotted?
Also, do you smell a strong fuel odor when it won't start? May be one or more stuck-open injectors, or the coil pack is bad.
Checking these in the order listed will more than likely fix your problem.
The clicking noise indicates the battery can no longer run the starter, which also means the fuel pump won't run either.
It could be a fuel issue. How old is the fuel filter? Can you hear the pump run for a few seconds when you turn the key on? Try turning the key to ON without trying to start engine three times waiting for the pump to stop running each time. Then try to start the engine. If it starts, Its a form of Vapor lock caused by the extreme heat we have had lately, and a weak fuel pump.
If none of this works, try a new fuel filter first. From there have someone check the fuel pressure regulator and then the pump. If you are in need of a new pump, take my word for it and spend the money to get one from a Dealer, and not from your favorite parts store. Most parts store parts are made in China and they are JUNK.
