1. Insert the driver installation CD into the computer, then wait for the installation wizard to load onto the screen. 2. Click "Next" on the welcome page, then follow the prompts of the installation wizard to completely setup the driver onto the computer. 3. Plug the USB data cable into the power port on the side of the Motorola RAZR V3 cell phone. Connect the other end into any USB port on the computer system. 4. Click "Start," "(My) Computer," then double-click the removable device icon. Select the "Music" icon to load a window with all the music saved on the cell phone. 5. Click-and-drag the music from your computer into the open window. You are able to copy over any audio track from a system media player, such as Windows Media Player or iTunes (open the program, then click-and-drag a track into the window). Repeat this process with any other audio file. 6. Close out the open windows, then right-click the removable device icon and select "Eject." Disconnect the Motorola RAZR V3xx from the computer once the icon disappears.
if you plug in your computer it tell you to what to load music now that y it show turn to blue to load music
go to start on your computer then my computer you see you mp3 icon drag all your music to te mp3 icon
1. Double-click on the "iTunes" icon to open the program and then transfer all of your music files into iTunes. To add music from CDs, simply load a CD into your computer's drive, wait for iTunes to see the playlist and then click "Import." To add music from another program,
go to the "File" menu and select "Add to Library." You will then be able to click on any music files you would like to transfer.
2. Plug your iPod into a USB port on your computer and wait for iTunes to automatically recognize the device. You will be asked to name and register your iPod, after which you can click "Finish" and begin to load music.
3. Click on "Library," found in the left hand column to reveal all of the music you have transfered to iTunes. To load songs onto your iPod, highlight one or more songs and then drag them to your iPod. Your iPod will be found in the same column where you found the library, under the name you chose earlier. As soon as you drop the files into your iPod, they will quickly copy.
4. Eject your iPod once you have loaded all of the music you'd like by clicking on the arrow next to your iPod's name. When the name disappears, you can remove the USB cable and begin enjoying your portable music.
Ok, plug your mem. stick into your computer. if you don't have a slot it fits in, then leave it in your PSP and plug the PSP into your PC with a USB cable.(You cannot put music or anything else for that matter without a Memory Stick Pro DUO and a computer or PS3. If you dont have a USB cable or a slot for the mem. stick, this wont work.) Click on the start menu, go to My Computer, look for the REMOVABLE DISC J: (or K:, at least that's what mine says.) Double-click on the icon. when it loads, right-click, go to new, and select folder. Type the name "MUSIC", all caps. Open the folder then drag your music tracks into the window. You're done!
Connect iPod to computer.
Open up iTunes.
Click on the icon on the left sidebar of iTunes that says "iPod Nano".
Click on the Music tab.
You will notice that at least one folder has been set to "Sync music" - the songs in these folders will be automatically loaded onto your iPod everytime you connect it to your computer. I would suggest separating the music folders that you use and the folders that your wife uses on your computer itself. Then, you can sync only the songs in your own personal folder.
Alternatively, you can disable the "Sync Music" option altogether by unchecking the box.
Whichever choice you make, you will now need to manually go in and delete the songs you don't want.
You can do this by clicking on the Music icon underneath the iPod Nano icon on the left sidebar of iTunes. Find a song you no longer want on your iPod, right-click the song, and select delete.
The mp3 player must be plugged into usb device of your computer There should be a new mass storage icon if you click my computer. Click on that icon. drag and drop songs into the mp3 player in the music folder.
Hi, First, you should use itunes for you iPod. I know that there are other programs that can let you load music on it, but you should use iTune, Really.
1. You should first download iTunes. It is free.
2. Next. Load your music into iTunes. Do all of this BEFORE you plug your iPod into the computer.
3. Connect your iPod to the computer. Use a fast USB port. These are usually located on the back of the computer.
4. Your iPod should appear in the iTune pane on the left side. You should be able to see a set of 'tabs' that you can click. The first one is about your iPod.
5. At this point, you can click on the music tab to tell the computer to load what to load into the iPod. Click 'sync' to load your music.
6. When the syncing is complete, you will see that notice above in iTunes. Click the arrow next to the iPod picture in the iTunes pane to discharge the iPod. The iPod picture will disappear. Make sure that you also safely release the iPod in the task bar at the bottom of the computer. You will need to click on a green icon that looks like a plug and select 'safely remove storage device'. Wait until the computer tells you it is safe to disconnect it. Then disconnect.
Hi, You will need to download the latest version of iTunes. It is free. When you have done that, load all of your music into iTunes. Then connect your iPod to the computer with the internet connected. You should be able to see your iPod on the left side of iTunes. You can then click the music tab to tell itunes what music to load into your iPod.
Be sure to click the arrow next to your iPod when the syncing is finished to release your iPod from itunes. Also click the green plug icon at the bottom right of your windows screen. If you cannot see the plug, click on the white arrow until you see the green plug. Click on it and you will see your ipod listed as a mass storage device and a message asking if you want to disconnect it. Click disconnect mass storage device and wait until you see a message saying ;safe to disconnect mass storage device. Done. Hope that helps.
just plug the phone up to your computer via usb your computer should then load all the neccesary drivers from there a folder will appear select view all files and folders in there will be video music and photos just drag and drop your music into the music folder and your done easy as that
