All the controls are on the top. Using self clean excessively causes damage to electronic circuits.I do no advise the usage of self clean especially for something as complex and expensive as this bad bot. I have the repair manual for this oven. I am trying to get it to download where I can send it to you. It is 55 megs. I need you to comment back so I can have a way to link it to you when I get it loaded to Gdocs. Dang computers. Wish I had a faster one but I fix stoves not pcs. LOL Whats gonna happen is My 30 minutes is gonna be up before I can get you the document. Waiting for your reply.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
I am gonna have to maybe mail it, look around my webpage for the manual section:
SublimeMasterJWs Money saving tips
Give an email address so i can send you the manual. The file is too big to load onto my webste, I am out of broadband space.
I am now gonna attempt to upload the manual directly to the Fixya manual section. Wish me luck
I just thought of something. I might try it. I cannot email this manual because the file size is too big and I cannot load it into google docs because it is too big. I bet I could burn it into a cd and mail it to you if I could figure out how to burn a cd. If I had your address and a blank disk I could try and burn it to that disk. you mail me one and a self addressed stamped envelope and i will try it. Mail me some directions how to using windows media which I have. I am an old guy who don't know nothing about these computers.
Do you see any Error Message on the Display?
If not, then it should not be a Concern. More often this could be Thermal Fuse on the Back of the Unit ( On Most Models ) will stop the Broil and Bake from Turning ON. You would just start a bake cycle and the temperature will sit at 100 and something degrees and never raise.appliance.
Let me know, once you check the same.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Lets talk about the top conv oven. what make it a convection oven is the air flow during bake . (it causes a all over even tempt that not only cook more even but faster . ck the fan as the element's are probably ok . the bottom oven tempt is controled by the oven probe. it may be bad . I'd change it . hope this hepls . ****
The display does not show any error message, but if I put the oven in Convection Bake mode, the fan runs, the "heat" light comes on, but the oven doesn't heat up. Since the convection bake heating element is distinct from the thermal upper and lower elements I suspect that the problem could be either the heating element itself or the switch/wiring for the mode.
I think I need advice from an expert familiar with this particular unit, not ovens in general. I know from reading the users manual that there are upper and lower heating elements that are used in the normal thermal oven modes as well as the Convection Broil and Roast modes, but during Convection Bake, only the Convection heating element is in use. It is this mode that is not working properly.
If you can get me the manual, that would be great. I suspected that the issues were possibly related to the use of the self clean cycle, and wanted to be able to narrow it down to the electronics or the heating element before tearing it apart.
I looked at your site, but didn't see a manual associated with the Bosch oven. Am I missing something?
thanks...
Here is my address:
[email protected]
Try zipping the file to compress it. 55 megs might exceed my attachment limit.
thanks
I m having exactly the same problem. Did you find the fix for yours yet?
