20 Most Recent Bosch HBN 455 Stainless Steel Electric Double Oven Questions & Answers
Fan won't turn off & upper oven work in Manual mode
This sounds like a control panel issue, you may have to replace it, about $300.00
7/9/2017 11:18:46 PM • Bosch HBN 455... • Answered on Jul 09, 2017
3answers
I have a Bosch HBN 455 double oven with the
Do you see any Error Message on the Display?
If not, then it should not be a Concern. More often this could be Thermal Fuse on the Back of the Unit ( On Most Models ) will stop the Broil and Bake from Turning ON. You would just start a bake cycle and the temperature will sit at 100 and something degrees and never raise.appliance.
Let me know, once you check the same.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
3/14/2016 4:24:08 AM • Bosch HBN 455... • Answered on Mar 14, 2016
0answers
Bosh double oven. Temp is 100 degrees cooler on
The fact that top oven is 100degrees less than bottom is no relation between the two; they are controlled by independent stat controls and if the only way you know if the temp is correct, is to set a temp (such as 350 degrees) and put a thermometer in that oven to see if the thermometer is with in 25degrees of the control settting. You need to do this for the bottom oven as well to see if it is aslo within 25degrees of the setting. then you make adjustments for each unit independently. If the controls are mechanical (knob), then the adjustment is within the control (usually by removing knob and serching for a small screw). If the controls are electroonic, then you need to search the circuit board to see if there is adjstments mounted on the board. Goodluck,Macgivor
1/31/2010 8:16:19 PM • Bosch HBN 455... • Answered on Jan 31, 2010
Inner glass door lower double ove
Many teasons for this to happen, no one has come up with a definitive solution for this,it just happens..
All you can do is have it replaced.
12/15/2008 8:31:26 PM • Bosch HBN 455... • Answered on Dec 15, 2008
2answers
Bosch HBN 455 Oven Cooling-Fan Issue
After the oven is switched off, the after-run of the cooling fan is controlled by an electromechanical thermostat switch. The fan can switch back on, due to residual oven heat that accumulates within the oven's outer case and reactivates the cooling fan temperature switch. Considering yours is making buzzing sounds and activates on and off, the fan's thermal switch may have dirty contacts or just be defective and require replacement.
12/19/2007 4:45:52 AM • Bosch HBN 455... • Answered on Dec 19, 2007
4answers
Hi I have a bosch
Exactly what is going on with the oven? Maybe I can be of some assistance.
3/6/2024 11:10:16 AM • Bosch Ovens • Answered on Mar 06, 2024
I have a integrated Bosch oven and it bleeps when I open the oven door and when it has been on for over 30 mins. What does the beep mean?
Generally it tells you that the food is cooked if the 'integrated oven has a microwave function. Or of course it is a fault. You can often fix that with a Power Reset. https://www.google.com/search?q=integrated+Bosch+oven+and+it+bleeps+when+I+open+the+oven+door+and+when+it+has+been+on+for+over+30+mins ..
4/9/2023 7:54:55 PM • Bosch Ovens • Answered on Apr 09, 2023
2answers
Bosch single wall ovens where is the thermal fuse located
Hi! The location of the thermal fuse in a Bosch single wall oven may vary depending on the model, but it is typically located on the back of the oven. To locate the thermal fuse, follow these steps:
  1. Turn off power to the oven: Before attempting any repairs, turn off the power to the oven by unplugging it or turning off the circuit breaker that supplies power to the oven.
  2. Remove the back panel: Locate the screws or bolts that hold the back panel of the oven in place and remove them using a screwdriver or socket wrench. Carefully remove the back panel to access the components inside the oven.
  3. Locate the thermal fuse: Look for a small, rectangular device with two wires attached to it. This is the thermal fuse. It may be located near the top or bottom of the back of the oven, depending on the model.
  4. Check the thermal fuse for continuity: Use a multimeter to check the continuity of the thermal fuse. Set the multimeter to the ohms setting and touch the probes to the two terminals of the thermal fuse. If the multimeter shows no continuity, the thermal fuse has blown and needs to be replaced.
  5. Replace the thermal fuse: If the thermal fuse has blown, replace it with a new one of the same rating. Install the new fuse in the same location as the old one and reattach the back panel of the oven.
  6. Test the oven: After replacing the thermal fuse and reassembling the oven, turn on power to the oven and test it to ensure that it is working properly.
If you are not comfortable working with electrical components or if you are unable to locate the thermal fuse in your Bosch single wall oven, it's recommended to seek the assistance of a qualified technician. Kind regards
3/25/2023 5:49:23 AM • Bosch Ovens • Answered on Mar 25, 2023
My Bosch oven display flickers often. Other times the clock is displayed as usual. What does this mean?
first thing I would do is check the cables that go to the clock, if they are OK then you likely have a faulty clock module which will need to be replaced.
2/23/2023 12:55:56 AM • Bosch Ovens • Answered on Feb 23, 2023
2answers
The knob on my electric Bosch oven doesn't grip onto the shaft and keeps turning/ twisting round. the actual knob is ok and pulls off to check, but the problem seems to be with the white plastic shaft
Get some epoxy putty, grease the shaft with Vaseline, put a small pea size piece of epoxy rolled thinly and insert it into the knob where the flat part registers on the knob. Push the knob into place and leave it 24 hours to cure. I use this.
Epoxy Putty - Amazon.ca
https://www.amazon.ca > Epoxy-Putty > k=Epoxy+Putty Results 1 - 48 of 696 - Epoxy Putty Stick, Yanyi Moldable Epoxy Glue for Crack Damage Fixing Filling or Sealing. Fast Permanent Repair for Metal, Glass, Wood, ... ..
2/9/2023 6:51:00 AM • Bosch Ovens • Answered on Feb 09, 2023
Replacing Thermostat in Bosch HBL455AUC
Yes, the tube is fed in from behind or above. Some thermostat bodies have a small adjusting screw to allow you to calibrate if it is fairly close. The videos show it is a simple job.
1/23/2023 12:11:58 AM • Bosch Ovens • Answered on Jan 23, 2023
Bosch convection microwave HMC87151UC does not heat in convection mode.
The issue you're experiencing with your Bosch convection microwave not heating in convection mode could be caused by a few different things. Here are a few things to check:
  1. Check the settings: Make sure that the microwave is set to convection mode and that the temperature and time settings are correct.
  2. Check the element: The bottom heating element is responsible for providing heat during convection mode. Make sure that the element is not damaged or burnt out. You can visually inspect it, if it is damaged it will need to be replaced.
  3. Check the fan: The fan is responsible for circulating hot air during convection mode. Make sure that the fan is not blocked or damaged. If it is, it will need to be replaced.
  4. Check the control board: The control board is responsible for controlling the functions of the microwave. A malfunctioning control board could prevent the microwave from heating in convection mode.
  5. Check for a blown thermal fuse: A thermal fuse is a safety device that cuts off power to the oven if it overheats. If the thermal fuse is blown, it will need to be replaced.
  6. Check for a blown thermal cut-off: A thermal cut-off is a device that cuts off power to the oven if it overheats. If the thermal cut-off is blown, it will need to be replaced.
1/14/2023 11:05:03 PM • Bosch Ovens • Answered on Jan 14, 2023
Bosch HBN 455 Stainless Steel Electric Double Oven Logo
Popular Tags
18 questions posted
Top Bosch Ovens Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a Bosch Oven Expert? Answer questions, earn points and help others
View Most Popular
Bosch Ovens
  • Bosch Ovens
Most Popular Question
bosch hbn 455 double oven
  • Ovens
