20 Most Recent
Bosch HBL 455 Stainless Steel Electric Double Oven Questions & Answers
Double oven / convection not working
It is likely that the convection element is burned out and needs to be replaced. If all other functions are working then this is the place to start. Teh back panel inside of the oven can be removed by removing the 4 visible philips screws on it. The element should look smooth and round, if not then it needs to be replaced. Be sure to turn power off to the oven before replacing it. Remove the screws that fasten the element to the back wall and gently pull the element away from the wall an inch or so. the wires will be exposed and can be unclipped from the element do not let them fall inside of the back of the oven or you will have to remove the oven from the wall to get at the back panel. Install the new element in the reverse procedure.
If the element looks good then it will have to be tested with a multimeter to verify that it is still good before proceeding to check the selector switch for burn marks.
F31
If the cooling fan is constantly running then means thermal overload probably faulty, it has failed in closed position.
Best to get an engineer to help
warmest regards
Richard the Repairman
Bosch HBL755A . Time on display continally blinks
now,
Turn
the oven off at the circuit breaker and wait for more then 5 minutes
and then turn breaker back on.this will reset the oven.this is the only
way to reset.but if you have tried this same procedure and this did not
help, then it might be the problem with door switch or door
assembly.
it got burn't and due to this the door latch is stuck and
its not releasing the door and so, unlocking door message comes up.
for more detailed trouble shooting please click on this user manual link
directly here
You
can get required parts from here
