It means what it says! i.e. water is not getting into the machine, the inlet hose or path is blocked or the inlet valve has failed.
You need to turn off power and water and check it is getting water through inlet hose and that the inlet filter is clear, the filter can be seen on the valve when you remove the hose.
You will need to open the machine to check the inlet valve and tubing.
Hope that helps
please vote
hi there ....the wiring schemematics can be obtained from meile with no problem .....if you can tell me what area in uk youn reside i can advise you where to obtain your diagrams
red light is check drain?
Clogged by something.
Could be a coin.
Use to have large coin when i was young and forgot remove from my jeans. So mum made me repair that every time. In that case filter clean, but coin bloking filter inlet.
Not necesarily coin in your case.
never buy these deals over Ebay my advice.
If you have the machine already then this is first to look for.
