Inter-Tel Intertel 6123300 GLX Executive Phone Logo
Posted on Dec 22, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Speed dial help
We need help resetting the speed dial numbers for our Inter-tel/Glx phone phones. We have no manual on it
george peters
Level 3:
President:
  • Inter-Tel Master 860 Answers
  • Posted on Dec 22, 2009
george  peters
Inter-Tel Master
Level 3:
President:
Answers
860
Questions
0
Helped
609363
Points
3471
To set speed dial numbers,with the handset down press the SPDL key(the key should flash)
enter in the 1 digit memory location code (1-9)
enter in the telephone number (up to 32 digits)
then lift and replace the handset. You should hear a confirmation tone and the SPDL key will stop flashing
To use pick up the handset, access a line and press SPDL and the location code (1-9)
How to set up speed dial?
Speed dialing is a default feature for all phones from 2G and upwards.
First go to your settings(call settings) and check that the function for speed dialing has been enabled; ON. The rest is automatic ...just press and hold any of the phone buttons from 2,3,4....0 and follow the prompt that comes up on your screen.This will allow you to assign speed dials to the digits 2,3,4....0 on your phone.
2helpful
I have a toshiba DKT3512S and need to reset the time, also i would like to know how to do speed dials. Thanks mara
You will have to get into program mode for this. you will have to press this sequence of buttons. Hold*#*#1*2*3*. Password is default to 0000. Program number is 902 then press hold. Press Intercom button for Date and line 1 button for time. If you press Intercom #66 enter speed dial number 10-99 is station speed dial. If you press Intercom #66 and enter speed dial numbers 100-999 will be system speed dial. Hope this helps. I included a site below with program manuals.
http://www.wedophones.com/ToshibaManualsLead.htm
Saving the time and date after programming it in
If you dialed feature 00 to access the mode, you must diall feature 00 to exit which will save information.
5helpful
How to program speed dial on sony spp-a946 cordless phone
  1. Press 'PGM'- "program" button.
  2. Press "speed dial" button.
  3. Select "station # " i.e. any button from 1-9 for speed dialing.
  4. (make sure to make a note of this selected # against the corresponding tel # and /or the person's name)
  5. Dial the complete (incl. 1 for USA or country code for other country tel. #s) telephone number to be stored for the selected speed dialing station #.
  6. Press "PGM" button again to complete the storing of the tel #.
  7. Test, after dial tone, by just pressing the selected station #
2answers
Intertel GLX phone rings busy unless unplugged
You could have a bad phone try to swap it with a working one. If that does not work there could be a problem with the port in the system or cabling. Move to a new port or new cable
I can't reset my speed dials for my RAZR V3m!!
you dont really have to redo the numbers again..you could just replace the speed dial you want with the speed dial number but if you still want that number just jot the current speed dial number down and then replace it with the one you want and do this for any other numbers you'd want to change..its simple really :)
How to set numbers on speed dial
Main support number 1-800-338-9549, I'm sure they can help you
67helpful
8answers
Canon LaserCLASS 710 Fax Owner's Manual
Set Speed Dial / One-Touch Feature
  1. Open One-Touch Speed Dialing Panel and press “Data Registration.”
  2. Under “Additional Functions” scroll to find “4. ADD. Registration” and then press “Set.”
  3. Scroll to find “1. 1-One-Touch Speed Dial” and then press “Set.”
  4. Under “Tel # Registration” scroll until the desired “One-Touch” number is displayed. Press “Set.”
  5. Under “Tel # Registration” scroll to find “1. Tel Number Entry” and then press “Set.”
  6. Under “Tel Number Entry” enter fax number (with “9” and the area code – ex. 913104454200) and then press “Set.” Screen will display “Data Entry OK.”
  7. Under “Tel # Registration” scroll to find “2. Name” and then press “Set.”
  8. Under “Name” enter the company name and press “Set.” Screen will display “Data Entry OK.”
  9. Press the red “Stop” key on the main control panel.
  10. The “One-Touch” feature is now set.
Label corresponding “One-Touch” button with company name.
Top Inter-Tel Lands Phones Experts
k24674
Are you an Inter-Tel Lands Phone Expert? Answer questions, earn points and help others
