20 Most Recent
Inter-Tel Intertel 6123300 GLX Executive Phone Questions & Answers
Speed dial help
To set speed dial numbers,with the handset down press the SPDL key(the key should flash)
enter in the 1 digit memory location code (1-9)
enter in the telephone number (up to 32 digits)
then lift and replace the handset. You should hear a confirmation tone and the SPDL key will stop flashing
To use pick up the handset, access a line and press SPDL and the location code (1-9)
12/22/2009 4:29:29 PM •
Inter-Tel...
Answered
on Dec 22, 2009
Intertel GLX phone rings busy unless unplugged
You could have a bad phone try to swap it with a working one. If that does not work there could be a problem with the port in the system or cabling. Move to a new port or new cable
7/24/2009 5:48:28 AM •
Inter-Tel...
Answered
on Jul 24, 2009
I need my phone to ring at my desk
Turn the program toggle switch on (right side of KSU), go to the phone to be programmed and press the # button, then press the line button to ring, then pick up and then hang up handset. You should hear a confirmation tone. This will affect all line buttons, even the ones not pressed. Any line buttons not pressed will not ring. Do this at each phone.
7/24/2009 5:40:08 AM •
Inter-Tel...
Answered
on Jul 24, 2009
Calls dont go to voicemail
The "Recall" Destination of that phone needs to be voicemail. Usually 2500. You have to go inti database programming to make that happen.
How can I change the language to english
A phone user can change the assigned language for the phone by entering the Change Language feature code while the phone is idle.
The feature code is 301. or <Special Key> 301 if the Special Key is forced on. This will toggle between the langeges until you get back to English,
