Screen Noise There appear fixed vertical/horizontal noises on samsung lnr 328w lcd tv. They appear at times, but, disappear if turned off. When appeared, all images are shown behind the fixed noises. Because this problem happened after warranty period (purchased about 2 years ago), they say that I have to pay for it. However, it seems that this problem is caused by manufacture's defacts. Do you guys have any solutions?
Here's another image with noises. In between "Baby Einstein" and "Baby's Favorite Place," there are noises in the shape of broken pixels.Here's another image with noises. In between "Baby Einstein" and "Baby's Favorite Place," there are noises in the shape of broken pixels.
I have a LNS4096DX samsung, and I have a very simialar noise problem just a little higher up on the screenm, i was able to eliminate it by using 720 input signal as opposed to 1080, but now it is present on all signals. how much is that board you are talkng about,, and where can i get one I have a LNS4096DX samsung, and I have a very simialar noise problem just a little higher up on the screenm, i was able to eliminate it by using 720 input signal as opposed to 1080, but now it is present on all signals. how much is that board you are talkng about,, and where can i get one
I have several lines of this noise going horizontal across screen. Many colored dots blinking.I have several lines of this noise going horizontal across screen. Many colored dots blinking.
I ended up running my TV without the rear cover and simply wiggle the defective connector slightly whenever the image deteriorates. I ended up running my TV without the rear cover and simply wiggle the defective connector slightly whenever the image deteriorates.
This is why you should always keep these high-tech TVs under an extended warranty.This is why you should always keep these high-tech TVs under an extended warranty.
You can't post conmments that contain an email address.
Hello LNR328W You have a bad T-con board. This board is mounted directly on the panel. Its located near the top of the set in the middle. This part is sold with the panel which makes it expensive. I have a few T-con board in stock. Let me know
Jan 7, 2010 - 26 posts - ā15 authors
Hi, I have a Samsung LN40A550 LCD TV which I have had for just over a year. ... I was watching TV yesterday and all of a sudden the picture went all. ... started makinga very high pitched buzzing sound with no picuture coming on. We did have a bunch of green vertical lines, but now just a black screen.
? 2:49
https://www.youtube.com/watch?v=h4XWCxUsSVU
Sep 2, 2014 - Uploaded by ShopJimmy.com
I have thin horizontal black lines on the top and bottom areas of my TV. .... Hi, I have a 2011 64-inch 3D Samsung PN64D8000 Plasma TV.
? 4:52
https://www.youtube.com/watch?v=k2QpYJp6MU8
Apr 12, 2014 - Uploaded by cr4zyw3ld3r
Hi my LG 47ln5700 tv set has thin greyish black horizontal lineson one side of the .... I hope this works good with Samsung LCD as well....
If I'm understanding this correctly, you have a faint line, horizontally on the screen that moves vertically right? if so, It's AC noise. If you are mechanically inclined, the quickest fix is to replace your current AC outlet with a GFI outlet. Works 99% of the time. Hope this helps.
when I turn off and then Turn on after 10 minutes the TV notwork(by using remote or touch button). I try to disconnect power supply andthen reconnect and waiting a couple of minutes and turn on but no work (nosound and black desktop) .I repeat this procedure many times so some timework and sometimes not work. please help me to solve this problem
90% of the time this is caused by a bad LCD panel. The other 10% is caused by a bad Main board. You may want to try and change the main board first. This set carries 2 different type of main board. You MUST look at your Version Number located on the side of the unit. (Version AM02 uses BN94-00667S.Cost $177.81) (Version 0001 uses BN94-00629R.Cost $176.14) LCD pane BN07-00194A Cost $806.49
Sounds like a bad connection on a ribbon cable or plug comming or going to the LCD display. This is something you should not try to fix as these circuits are very very fradgile and you can easily break or tear a ribbon cable . Call the manufacturer to get a tech to assit you. Good Luck
