20 Most Recent
Samsung TXM3296HF 32" TV Questions & Answers
There is a lock in
Hello
I think your TV has been locked, and you have forgotten the four digit V_Chip code you have entered earlier. If so there is a method to refresh the V-Chip code. The orginal code for the V-Chip, when the TV exits the factroy is set "0000".
You can set to this code by the following method.
Press the remote control keys in the following sequence, which reset the pin to "0000".
POWER OFF==> MUTE==> 8==> 2==> 4==> POWER ON.
TV will come with a fresh V-Chip code "0000", which you have to readjust to block any channels if you wants. Ok.
11/6/2010 2:04:20 PM •
Samsung...
Answered
on Nov 06, 2010
SONY DVD REMOTE CODE FOR SINOTEC LCD
I just followed the instructions to program the Samsung remote (Press tv button then press and hold the power button whilst pointing at your TV and type in the code) ....I went through every code until my TV turned off....The code for my Sinotec is 75
9/12/2010 5:04:59 PM •
Samsung...
Answered
on Sep 12, 2010
Sinotec TV Locked
we need a factory setting of I.c LA76932n 7n and program no is 56v6
8/6/2009 8:52:48 AM •
Samsung...
Answered
on Aug 06, 2009
Samsung txm3297hf will not start
R 818 is off value or the IHVT needs soldered or replaced.
That's what I have seen...
Call your Samsung Authorized Service Center, they have the SUPPORT of Samsung to fix these faster
1/29/2008 3:18:16 AM •
Samsung...
Answered
on Jan 29, 2008
Samsung
Yes if the code fits
you have to get one with
the same basic specs.
as the tv
11/24/2007 4:26:11 PM •
Samsung...
Answered
on Nov 24, 2007
HD distortion Problems
have a tech change your your vertical ic.there is also 1mf 50v cap that is located in the vertical circuit that usually goes bad have it change.good luck.
8/4/2007 11:35:52 PM •
Samsung...
Answered
on Aug 04, 2007
