20 Most Recent Samsung LN-S4051D 40 in. LCD Television Questions & Answers
My Samsung LCD TV will not turn on, it just clicks
A Replacement Power Supply.
Parts: £80 - £110 depending on the model.
Labour: £40 (ish) little bit more with a 90 day warranty etc.
Type your model number into www.chsinteractive.co.uk for the price on a PSU.
Good Luck.
5/17/2022 10:01:01 AM • Samsung... • Answered on May 17, 2022
13answers
Will not turn on or off
I had the same problem. I work for a mother board manufacturer w/offices in New Jersey and brought mine into our engineering lab after Samsung told me tough luck. Anyway, one of my engineers fixed it in 10 minutes. Essentially, he replaced the 1000uF capacitors on the power supply board with 2 cent capacitors instead of the 1 cent capacitors that had blown out on the CHEAP SAMSUNG POWER SUPPLY BOARD. You can tell the caps are blown via visual inspection. The top of the cap should be perfectly flat and a blown cap will be convex on top. Unfortunately, there are also 2500 uF caps by the same cheap manufacturer on the board as well and we don\'t stock that value for our products. According to my engineer, those will most likely blow next since he replaced the others with better caps, but I\'m getting samples of those and will replace them shortly. After that this piece of junk should last me at least another 2 yrs! It\'s been working for about a week now w/no problems. Hope this helps.
4/13/2021 9:19:35 PM • Samsung... • Answered on Apr 13, 2021
2answers
Ps43d 450a 2wxxu
A lot of flat panel tv's have crapo capacitors from China, and they interfere with 'ready' circuits. Replace main capacitors on ps area, TV should come on.
1/3/2020 11:50:16 PM • Samsung... • Answered on Jan 03, 2020
2answers
Bn44-00167a kit power hansol
Just search for the site named Electro-help. It has details about repair. I assumes that you're somewhat sound in electronics. You can get details there. Search for the site by Google
11/8/2019 2:45:35 AM • Samsung... • Answered on Nov 08, 2019
2answers
I have a Samsung with power board HANSOL
They sound like the High Voltage Ceramic Capacitors.
10/17/2019 7:33:49 AM • Samsung... • Answered on Oct 17, 2019
2answers
50 inch samsung tv clicks on and off when turn on
the Fuse needs to be Replaces, contact nearest samsung service center. would cost just $1 trust me
email me if you need any assistance ... [email protected]
10/16/2019 1:44:28 AM • Samsung... • Answered on Oct 16, 2019
I have an Samsung LN-T4066F 40 in
most likely you need a new mainboard it is the board that all the hdmi ports are on pull it out and get the part number off the board and search google for a new part buy it and replace it
1/2/2018 6:50:08 AM • Samsung... • Answered on Jan 02, 2018
Samsung dvd-r150 cannot finalize disc error
I've had that happen I will try cleaning them and you can clean your dvds also sometimes that works but after a while you just have to replace your player I've done that a few times hope this helps Merry Christmas
12/10/2017 3:48:32 AM • Samsung... • Answered on Dec 10, 2017
2answers
Hello...do hdmi slots eventually wear
yes so do hdmi cables
11/8/2017 12:33:45 AM • Samsung... • Answered on Nov 08, 2017
CHANGING THE CAPACITORS DID NOT
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electro-medical.blogspot.com/ http://homenol.blogspot.com/ http://electronicshelponline.blogspot.com/ If blinks continue without any pause, the main board is faulty. Search the site by type in the "brand name" to your device, [Exclude the model number] in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
7/18/2017 1:38:18 PM • Samsung... • Answered on Jul 18, 2017
My samsung 40 in lnt4061 occasionally has red and
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
6/10/2017 8:45:46 AM • Samsung... • Answered on Jun 10, 2017
2answers
Samsung TV--fire hazard??
You have measures the cable coming in , go from the center conductor to the braided ground sheath, I really think the problem is with the cable not the TV.
5/4/2017 10:30:40 PM • Samsung... • Answered on May 04, 2017
NEED VALUES FOR CAPACITORS LE40A656A1FXXH
those values are printed on the side of the capacitors. You can tell which ones need replaced by their bulging tops.
1/3/2015 4:16:44 AM • Samsung... • Answered on Jan 03, 2015
2answers
Wall mounting tv. How do I get the base Off?
Are you wanting to sell the base? My base is broken and I am trying to buy one.
10/29/2014 1:53:48 AM • Samsung... • Answered on Oct 29, 2014
46 inch Samsung TV that just clicks but wont turn on
I just fixed this very same problem. It is the capacitors are the problem. However, I think that if you have some minimal skills with soldering, you can fix this yourself. You just need to take out the system board, then the power supply parts are on the top right. The bad capacitor(s) will be bulging at the top and possibly have some brown stuff coming out. The ones that go bad are 1000microfarad, 10V, however you can replace them with higher voltage. I got 35V caps from radio shack for 1.59 each. You just need to solder out the bad ones and then put the new ones in and solder. Remember that the negative end goes on the side with the bold black part of the circle on the system board. Then just cut off the extra ends of the capacitors. If you are capable of doing this yourself, you will spend at most 6 dollars instead of however much a technician costs.
10/19/2014 12:03:08 AM • Samsung... • Answered on Oct 19, 2014
Samsung LN-S4051D 40 in. LCD Television Logo
320 questions posted
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
View Most Popular
LN Samsung
  • LN Samsung
Most Popular Question
50 inch samsung tv clicks off when turn
  • Televison & Video
