Make sure everything's connected in the correct sockets. Turn the SNES on, change to one of the Analogue channels (one of the channels which you control with the TV remote) and start scanning for a signal. The RF cable has to be connected to the analogue port (where a TV aerial would plug in to get analogue channels) and the SNES needs to be switched on.
The alternative is to get a SCART-compatible cable that works with a Gamecube or an N64 and use it with the SNES, as Nintendo had the foresight to add an EXT port which'll let you play the SNES on an AV channel.
If the RF switch comes with a power cord on it, it MUST be plugged in to work. Try plugging it in.
Also check your tv settings. I don't have an HDtv but I do know they have multiple options of "inputs"
If it is an RF modulator and not just a switch, check the settings on that as well. On the one I own I have to designate channel 3 or 4, that could make a difference.
Has your freeview tv got a built in RF i.e (not a digital freeview) tuner? If it hasnt then you wont be able to tune it into your LCD TV by connecting it through your aerial socket. However I think you can get a cable so that you can plug the nintendo directly into a scart or rgb input. Something like this.
Have you tried using a composite connection? Do you know how to access the SCART input on your set? Sometimes the channel up/down buttons don't get you to the A/V inputs.
