Sharp aquos LC-32D41U tv has been fine for almost 3 years now I don't get sound out of the hdmi inputs, have tried new cables in both jacks and no luck can someone help me please
I have a similar problem. The Sharp TV aquos appears to be shutting down my blue ray player and dvd recorder when connected via HDMI. They work fine and never close down when I connect them via the rca cables either single video connection or a composite 3 cable rca lead. I have 3 HDMI inputs on the tv and the problem occurs on all 3. Any suggestions?
I have had exactly the same problem. Sounds daft but by not using the remote, and only using the power on/off switch on the TV itself, it is working perfectly...no idea why
Use the remore for changing programmes etc but not for on/off
Try it anyway because I know how annoying this is
Good Day, Jamievass;
Please disconnect the NEW DVD Player, does analog stations come back? What input are you using; RF, Comp, hdmi? If ok try using another input or you may need a main bord that processes the signal.
Digital inputs on Aquos TV's are "always on," usually the HDMI inputs and DVI inputs. As opposed to analog inputs 1, 2, or 3, are only activated once something is plugged in. Try plugging in another HDMI sources into input4 or 5, if its still not working, the TV needs a new Main Board. Try calling Sharp 1-800-237-4277 and locating a local service center in your area.
Shine a bright light on the screen, do you see the image (but very very very dark)? If so, its either a bad inverter or lamps, which are only sold with the LCD panel as an assembly, which is very expensive (more than the TV is worth).
