Need help with the lux 7000, the light "bag full" is on and it will only turn on for 30 second at best. I've put in new bags and the "bag full" is still on. Can you help me
Try dialing the control valve to the mid way position. If the unit still shuts down with the bag full light on you have a damaged control valve under the dial on the top of the vac. This valve failure is common in this model and can only be repaired by someone with original AERUS Electrolux repair parts, generally at an AERUS repair shop.
It sounds like the valve assembly (full bag control) is faulty. Threr are two O rings inside of it and the plactic holding the bottom one has broken. You'll have to take it to the shop.
Once you change the bag, be sure to turn the machine off and back on to clear the fault. If it is the full bag light that is on, and not the "?" light, and you have a new bag in place, then you probably have a bad control valve. I would suggest finding the closest Aerus (formerly Electrolux) dealer and having them change it. It shouldn't be too expensive. If you have the "?" light illuminated, the bag probably isn't pressing the actuator like it should. When placing the new bag into the machine, be sure the bag top presses the small button in the lower right hand corner. Good Luck!
The problem was a sticking switch that was not being reset. The vacuum on/off switch mechanism is comprised of two switches. One is the main switch that turns the vacuum on and off. The second is a shut off switch that gets tripped when the full bag sensor is engaged. This second switch is supposed to get reset when you push the on/off switch on the outside of the machine. The full bag shutoff switch was stiff and it, therefore, was taking a couple of presses of the on/off switch to move the shutoff switch back into the running position.
Either there is something wrong with your switch. Which it doesnt sound like it. Take it to your dealer or call another one it sounds like the control valve needs to be replaced. I am a dealer 1-866-966-9350.
