Amana 29 in. ACC4370 Electric Cooktop Logo
Anonymous Posted on Dec 06, 2009
The dual element does not hold at medium heat.
The dual element does not hold medium heat. Seems to either be off or max. Is this a normal failure mode for the switch? Do these switches fail a lot? could it be the element itself? Thanks, Bob
Anonymous
Level 3:
  • Master 1,891 Answers
  • Posted on Dec 07, 2009
Anonymous
Master
Level 3:
Answers
1891
Questions
0
Helped
409484
Points
5205
Repl the sw / not a uncommon repair .. mm . element is ok .. sw's are geting better ..
Testimonial: "Thanks!"
How to replace an element
This could be a couple of issues, but unfortunately if it's your element, you would have to replace the entire element, not just the middle part. What's the rest of your model number? I can find a part number for you. (KECD806R****)
How to replace element in KitchenAid KECD806R
I've replied to your other post as well. Please regard that answer :)
Jgd8348bdp burner not working
SEE PICS Or Oven safety valve needs to be checked with multi meter ohms / voltage
ALSO Test the Burner Heating Element
The stove's burner heating element is a coil of metal sheathed in an insulator. Electrical current travels through the element. Resistance to the passing of electrical current causes the element to heat up. A precise temperature cannot be set for a burner, instead it is turned on and off repeatedly by the control to the achieve an average temperature. When it is set to a low temperature, the element is cycled on and off more frequently. For high temperatures, the heating element is energized longer with fewer on and off cycles. Some burners have two elements, with the second only being used only for high heat settings.
Before testing the heating element, unplug the appliance or shut off the power at the fusebox orbreaker panel to avoid an electrical shock hazard.
When a burner does not heat at all, or only heats up to a lower than expected temperature, the problem is likely to be with the heating element, the temperature control switch, or the wiring. If it only heats at the highest temperature, the problem is with the control or an electrical short, not the burner. If the burner works only intermittently, the problem is likely in the wiring or connectors. To test the heating element, try the following steps.
First, disconnect the heating element from the stovetop. In most cases, this is done by lifting up the burner on the side opposite of the terminals (the part of the burner that disappears under the stovetop). Remove the decorative ring.
Inspect the style of connection. If the burner element has visible blades that fit into the receptacle block, pinch the block with one hand, and pull the heating element free with your other hand. If the terminal block clamps over the element, the housing must be removed and the burner wires disconnected. Unsnap the metal piece or remove the screw that secures the receptacle block and then disconnect the element.
Inspect the heating element. If you find bubbles, warping, or damage to the insulation sheath, the burner must be replaced. If the terminals are dirty or corroded, this can cause poor temperature control, intermittent problems or complete failure to heat. Clean the terminals with steel wool or very fine sand paper to restore good conductivity. Test the resistance of the heating element using a multi meter. Set the multi meter to the ohms setting X1 and touch one probe to each of the terminals. A normal reading is typically somewhere between 20 and 120 ohms. The exact reading differs by manufacturer and mode. If the meter reads infinite resistance or the other extreme of the scale, zero resistance, then the element is damaged and should be replaced. If the measured resistance differs significantly from the expected range, the element is probably bad, but if possible, determine from the manufacturer what the actual resistance should be.
To test for a grounded or shorted element, touch one probe to the surface of the burner and the other probe to each terminal in turn. If you get continui
1helpful
Control for dual element has to be wiggled just so -so to shut element off, what do I need to fix it? Heats perfectly, shutting it off is my only problem.
The control you're wiggling (infinite switch)needs replacement. Model# and the position of the dual element (right or left, rear or front) is needed to get the part number.
Mar 03, 2010 • Cooktops
3helpful
3answers
Frigidaire ES340 Range One element from Dual element doesn't work
The elements DO BURN OUT. Replace it.
Often you can see evidence of a hot spot on the element where the final failure occured, but not always.
Oct 27, 2009 • Cooktops
1helpful
Wirlpool elect range GR465LXLS, cant control heat on dbl burner
yes it is your control infinite switch the knob swicht that goes from 1 to 10 or min to max thanks from gilles
Mar 13, 2009 • GE Cooktops
1helpful
Miele KM443. Elements switching on and off every 5 to 7 seconds.
as far i know it is normal if u put at high control after a sec,the sencor control is turn off then a sec again it open coz of the sensor, design the sensor for not overheating the hob.it is normal try to position the control in in not a max position.or the pot u use is exactly in the circle or bigger dont put a small one in the bigger hole of ur elctric hob.tnx
1helpful
Burner gets hot even when not turned on
sound like you have a shorted element, it will stay hot but not high heat hot (glowing) red, other posibility is bad infinate control switch that switch could be bad
Apr 13, 2008 • Cooktops
New Whirlpool Cooktop Problem...Maybe.
The function 3 element are normal / depend to the intensity adjustment / the small 4th element are set for pre heating w/out burning , try to sdjust in lower adjusment or ann switch for pre heating.
Dec 04, 2007 • Cooktops
Top Amana Cooktops Experts
Paul Carew
Thomas Perkins
Thomas Perkins
Are you an Amana Cooktop Expert? Answer questions, earn points and help others
