Exit transistor A1489 and C 3853 for a Denon Model DRA 275R E154610
My set does not turn on and I was told these are the parts that I need but I do not know where to buy them
Listen for a relay clicking inside. It you hear it but get no power, it is a problem with the relay. If there is no click, it is probably the power supply.
Check on the back of the unit for a switch marked "channel step" or something similar.Usually close to the anntena socket or connection.When you find it switch it to the alternative position.This should solve your problem.
Check the electric outlet to make sure the polarity isn't reversed, which can cause static. Also, check the outlets in the room to make sure they are all grounded which can also produce static. Also, certain cell phones operating a different frequencies can produce a static.
I have traced the fault to the rf amplfier transistor in the tuner "can" It is a 4 pin item with 6JK85 on the encapsulation but have been unable to source a replacement. Can anyone help?
