Here is something you can try.
On your source check the output level for your sub.
Try setting up at a higher level, if at 1 set it for 2 or 3
Then adjust the volume control on the sub down to mach the speaker volume level.
Testimonial: "Sorry for the delay, I took your suggestion and made the adjustments. Have not had the issue re-occur since Nov. 29 when I made the changes. Thanks!"
Too early to rate, your suggestion is one that I have not thought of... Sounds reasonable, will try and let you and everyone know the outcome...
Thanks,
Robert
