D-Link DIR-450 Router (DIR450) Logo
Posted on Nov 24, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Unit see's KPC-650 but can't connect to ISP verion
  • tfmeudt Nov 24, 2009
    All I'm doing is upgrading to the D-Link, the card is activated and is being used right now in a KR1
    Under status:D-Link tries to connect but is unsuccesful
    This card is a KPC-650 that is activated and works on a KR1 router, it is seen and synced to the D-Link, but can't connect to the ISP:Verizon
Anonymous
Level 3:
Genius:
  • Master 1,689 Answers
  • Posted on Nov 24, 2009
Anonymous
Master
Level 3:
Genius:
Answers
1689
Questions
8
Helped
567723
Points
4681
If that is the case, the best way to resolve the issue is to uninstall and reinstall the device.
please refer to this manual:
http://www.kyocera-wireless.com/wireless/pdf/Vista_Drivers_Install_Procedure.pdf
Ekse
Level 3:
  • Master 13,435 Answers
Ekse
Master
Level 3:
Answers
13435
Questions
82
Helped
3985270
Points
38023
Hi First, are the drivers installed so that you can see the network but you just can't connect to it? Is the card activated? To get the Pc card activated contact the service provider I assume you mean Verizon United States Verizon Wireless www.verizonwireless.com 1-888-466-4646 When your card is activated you should be able to connect to Verizon network, this will have to be done directly with verizon we can't do it for you.
  • Ekse Nov 24, 2009
    sorry, could you explain what you are attempting to do, and post the brand and model of the dlink as well.
  • Ekse Nov 24, 2009
    I would highly recommend that you write out spesific and detailed questions of your problems in the future.
Dsl3780 internet light continues coming red and not converts into green after reset the router
you need to call your ISP
if they ISP installed that DSL3780
it only connects to a ASDL land line service, your ISP
no ISP stated by you but only THEY can make ASDL work.
RED LED means the ISP has a problem , activating the DSL modem inside your unit, only they can cure that. ok?
you need to call them and we are not them,.
Panasonic FX KPC 141
Call 1800-211-7262 for Panasonic's capable Technical Support; be sure to have the serial number of the product ready.
I have attached my DI-524UP to a new modem but now I can not use the internet. the wireless is working as it conecets but the internet is not connected. The lights are flashing on the front of the unit...
Your D-Link DI-24UP needs to "log into" your ISP's network again - by switching it to a new
(DSL? cable?) modem, your router lost its "login" with the ISP.
Solution: power cycle the router. This will force it to log back into your ISP's network, at which
time you'll have to supply (probably manually), your account name and password that your account
has with your ISP.
1helpful
I have an SB5102 modem, purchased from my current ISP in Canada. I am leaving the country and so discontinuing service. Can I use the modem for connecting to another ISP -- in the US or even in Europe?...
You are right in that your ISP is wrong that it won't work anywhere but with them. This type of modem is used all over the United States with different types of ISP. The thing is that you could try to hook it up with a small cable company in the US but it all depends on how they will except it. It always depends on what the companies rules are. In the United States you rarely buy a cable modem it just comes with the service.
ERROR MESSAGE lamp was over Canon DR-1210C driver
lamp was over Canon DR-1210C driver verion 1.01.10601.23003(-4430)
4helpful
MC50 Internet Access Issue
Go to Start > Settings> Connections tab.
click on connections icon and select advanced tab.
Click on select networks.
Ensure that both drop down menus are set to my isp rather than my isp and my work network.
This should get you up on the web.
Kpc-60 kenwood alarm
Out of production.Sorry, most if not all, systems like this were proprietary to begin with and internal wiring schematics were never made available...accordianman
2answers
Configuring modem so limewire and shareaza will work
have u dl latest verion of java and limewire do all windows updates run cclceaner tool ok
5answers
Sitecom router broadband wireless connection to Win XP
This detail will be provided by your ISP.
DSL usually requires PPOE.
If you need morer info, supply the name of your ISP, the service provided and the Make/Model of the router.
Top D-Link Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
