KitchenAid KSB5 Ultra Power Work Top Blender Logo
Posted on Nov 22, 2009
How do i remove the rubber clutch of my kitchenaid blender
Anonymous
Level 1:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Jan 15, 2010
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
5
Questions
Helped
30592
Points
25
Grab the blade with a rag so you don't cut yourself, then grab the clutch with another rag and turn CLOCKWISE. It's threaded reverse - took me hours to figure this out. I found grabbing with rags or maybe towels worked the best. That should work
How to open Kitchenaid KSB560OB to replace motor
Undo the 4 screws at the bottom. Before you do that though remove the clutch/motor drive. You cannot take the motor out with that still fitted.
On a KSB5WH4 how to remove & replace clutch?
it's reverse threaded. strike clutch firmly in clockwise direction with a screwdriver/hammer. it should spin right off.
1helpful
2answers
How to remove the cutters on model ksb560mco [email protected]
The cutters are part of the collar itself and not available as a separate part. If there is anything wrong with them you need to replace the whole collar. The collars are available on Amazon UK, K A Parts as well as other places.
How do I replace blender rubber clutch for Kitchen Aid blender
Hiya,
Sorry you are experiencing problem with your appliance. We have created help pages and videos to help you resolve this issue, please see the relevant links below for you perusal:
https://www.kaparts.co.uk/Help/KitchenAidHelp/KitchenAidBlenderHelp/KitchenAidSplitCouplerRemoval/tabid/180/Default.aspx
https://www.youtube.com/watch?v=Qy9gCwSgUVg
https://www.youtube.com/watch?v=nhnuaSCoVjQ
Hopefully you will find our information helpful. Should you require any help, please don't hesitate to contact us.
1helpful
Seems like motor has lost power
This sounds like the black rubber coupler has broken. The teeth often get knocked off. Have a look at the part shown in hte pictures here:
http://kitchenaidblenders.co.uk/Home/tabid/36/p/Two-%282%29-KitchenAid-Blender-Coupler-%2b-WS-Fitting-Tool-9704230_2plusWS/ProductID/175/Default.aspx
2helpful
I need to replace my rubber spinner with a new one. Where can I get the part and how do I take the old one off and put the new one on?
Hi, you have broken the coupler (sometimes called a coupling). It is relatively cheap and easy to replace. In the UK, K A Parts Limited sell them here and provide removal instructions here.
3helpful
Kitchen Aid Blender - blade not rotating
You will definitely need to change the clutch blade i.e. the black rubber rotating bit. Chaging it on the base unit may be difficult, I would check with your local Kitcheaid repairer for spare parts and repair advice.
Also check the clutch blade on the jug itself.
2answers
Top KitchenAid Blenders Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a KitchenAid Blender Expert? Answer questions, earn points and help others
