Mitsubishi TV model CT-29AB1(M),is having child lock.
how can i remove it ? i'm using the original remote control.
SOURCE: Mitsubishi Rear Projection TV
Easy! But you will need the original remote. On the remote is a button called QV for quick veiw. Press that button at the same time with the 9 button. This will open the lock, But it will return when you turn off the set and turn back on again. If you want it to do a normal turn on , once you open the lock you must go into the menu and remove the lock from the set completely. You may be able to find a friend or a store that might let you borrow an original remote? Sorry to be the bearer of poor news my friend. Good Luck
SOURCE: DURABRAND TV 2127N
The original replacement remote is available here: http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&m1=DU1901+&uid=11767457973430 For almost the same price as a universal one. Good Luck
