Okay jmurphy177...
You are now on record...
Any injuries or property damages after this are
COMPLETELY YOUR RESPONSIBILITY.
There is a SERIOUS reason the instructions say
to have a qualified electrician do the install...
Precisely...
There is
NO WAY this switch may be
turned around
and
IT MUST have a
NEUTRAL wire to
OPERATE CORRECTLY.
Quite often a switch box will only have the
hot wires extended from the light fixture...
The COLOR of the wires in that configuration
MEAN NOTHING... and you are creating an EXTREME
HAZARD.
Please heed this warning... Everything else =
negligence.
Most likely an ELECTRICIAN can run the additional wire you
need to function...
BATHROOMS are "WET" location and require SPECIAL SKILLS not to be
deadly.
Carnac the Magnificent
