Radio Communications Logo
Posted on Nov 11, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Bluetooth setup How do I setup this bluetooth with my G1 phone?
Anonymous
Level 3:
President:
  • Master 632 Answers
  • Posted on Nov 11, 2009
Anonymous
Master
Level 3:
President:
Answers
632
Questions
0
Helped
276587
Points
2196
You need to pair your phone with your bluetooth headset.
  1. Turn on your phone's bluetooth and search for bluetooth devices.
  2. While the phoneis searching and the BT headset is off, press and hold the call/end button on the bluetooth headset until it's light glows steadily. Do not let go until the phone finds it.
  3. Pair the devices and allow the BT headset to connect automatically.
  4. To connect, press and hold call/end button on BT headset like the one in step 2.
Bluetooth paired but not coneected
How to pair and then connect to a Bluetooth device on your T-Mobile G1 Google smartphone.
1. First, ensure Bluetooth is enabled.
2. From the Home screen, press Menu.
3. Select Settings.
4. Select Wireless controls.
5. Select Bluetooth settings.
6. The G1 starts searching for Bluetooth devices in range. Select the device when it appears.
7. Type the PIN for the device.
8. The device should then pair with the G1. You can then select the device name to connect.
Bluetooth only supports ad2p profiles for headsets, music, and sharing of contacts and pictures. This is limited by VZ. Until the phone is rooted, there is absolutely no way around this. You cannot send files other than contacts and pictures via bluetooth.
It sucks... I know. I am in the same boat. I am [im]patiently waiting for the droid to be rooted so I can use bluetooth to share files between two droids.
2helpful
I am trying to figure out how to send music files over bluetooth. I can turn on my bluetooth, then turn on discoverability, but don't really know where to go from there. I connected with my friend's...
HTC G1 android does not come with file transfer over bluetooth. What you have to do is root your phone and download apps like blueX to transfer files thru bluetooth. hope this helps
Oct 23, 2010 • HTC G1
1helpful
Want to use blue tooth to listen to music on my g1 instead of ear buds
U can connect your mobile to bluetooth headset. In bluetooth option there with be "Search for audio enhancement" option it will find out if your bluetooth headset is on and working. If u connect you can hear thru bluetooth. Pls vote for me if my suggestion is helpful.
Regards, Kesav
My fones blutooth isnt workin
Sounds to me like your G1 isn't set to discoverable. Should be an option for it in the bluetooth section. Then go ahead and try to pair them, also make sure your bluetooth is in pairing mode, most bluetooth headsets get be set to this by holding down the on button for over 5 seconds and usually shows as a constant blue light.
7helpful
2answers
I have a g1 phone and cant get or send pics by bluetooth
As of yet the T-Mobile G1 doesn't support file transfer via bluetooth. So your phone isn't faulty, it just isn't capable of it! Google say they may be releasing bluetooth file transfer support in a later update though.
Bluetooth not accepting anything
The T-Mobile G1 doesn't actually support file transfer through bluetooth :S So it's not faulty, it's just not programmed to do that. Sorry! However it should be able to find your bluetooth headset, it always finds mine. Maybe the headset is faulty?
May 27, 2009 • HTC G1
Google G1 bluetooth
Hello my name is Jennifer. Is there a wat to connect my G1 to my car stereo via tape deck or cd playerr?
2helpful
Bluetooth My husband and I both have upgraded to G1 phones and neither phone will connect to bluetooth, we have tried with several phones, we can pair up to another phone (and each other) but when we try...
hiya, the G1 does not let you connect to other fones and will not enable you to send ringtones pictures etc wether it is a g1 or any other make! t-mobile are working on this to set up the application! they will notify us g1 users when it is available. hope this helps you out
all the best
kel
x
Jan 02, 2009 • HTC G1
4helpful
3answers
Hi
I was trying to transfer some ringtones from old phone to G1 and facing the same problem.
And now somewhere from net I found the solution to my problem.
Although it could not be done by bluetooth, but my problem is solved now.
You can also try it. It may help you out.
> Transfer ringtones/music/photos from your phone to Desktop
> Connect G1 to Desktop by USB cable
> On the top of G1 screen it will show the icon of USB (connected)
> Scroll down from the icon and select 'copy files from computer'
> Select 'Mount'
> On desktop a massage will appear, click 'open folder & show files'.
> Copy & Paste files from computer to G1. Now your files are in G1
> If you want to set any song as ringtone press & hold that song, a menu will appear and you can select 'set as ringtone'
Dec 01, 2008 • HTC G1
Top Radio Communications Experts
eradiostore
eradiostore
 Grubhead
Grubhead
Are you a Radio Communication Expert? Answer questions, earn points and help others
