Drills Logo
Posted on Nov 10, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Spring return - Powermatic Drills
Anonymous
Level 2:
  • Expert 251 Answers
  • Posted on Nov 10, 2009
Anonymous
Expert
Level 2:
Answers
251
Questions
0
Helped
104090
Points
721
Paste this link into your browser address bar
http://www.toolsandmachinery.com/powermatic-parts-5882/powermatic-drill-press-parts-6903/powermatic-2800-parts-6904/
thats the diagram and parts listing for the only available powermatic drill press ( 2800) , if its an older model you might find the parts on ebay , i have in the past used a recoil starter spring but it can be a pain to modify the spring to suit .
hope this helps , if it does please vote :)
Where does the return spring attach to?
To reattach the return spring on your Hitachi C12LSH miter saw, follow these steps:
  1. Ensure that the miter saw is unplugged and turned off for safety.
  2. Locate the yellow protective cover on the miter saw. This cover is designed to shield the blade when the saw is not in use.
  3. Look for the small metal hook or attachment point on the yellow cover where the return spring should be connected.
  4. Inspect the return spring itself and identify the end that needs to be attached to the yellow cover.
  5. Align the end of the return spring with the attachment point on the yellow cover.
  6. Apply pressure and securely attach the end of the spring to the attachment point. It may require some force to hook the spring into place.
  7. Once the spring is properly attached, test the yellow cover by pulling it away from the blade. It should spring back into place when released.
If you are having difficulty locating the attachment point or need further assistance, consult the user manual for your Hitachi C12LSH miter saw. The manual should provide specific instructions and diagrams for reattaching the return spring. If you don't have the manual, you can usually find it on the manufacturer's website or by contacting Hitachi customer support.
tip
Replacing a Pedal Arm Return Spring on the Stairmaster 4000PT Stepper How To...
How To Replace a Spring on Stairmaster 4000PT
  1. Remove bottom cover.
  2. Unhook the pedal arm return spring from the spring hanger.
  3. Detach the spring from the step chain by removing the master link. The spring-chain connector is in good condition if it has an hour glass shape. Replace a worn spring-chain connector.
  4. Check to ensure that the spring pulley turns freely and is not worn excessively. Refer to the "Spring Pulley" section if you have to replace the pulley.
  5. To reinstall th spring, connect it to the end of the step chain using the master link.
  6. Route the spring under the spring pulley.
  7. Hook the end of the pedal arm return spring onto the spring hanger. WARNING: Do not twist the spring during installation. It will wear excessively and reduce the life of the spring.
How to Replace Pedal Arm Return Spring on Stairmaster 4000PT
PARTS FOR ORTHO LAWN SPREADER --SHUT OFF BLADE RETURN SPRING
I have a Chevron Ortho rotary spreader, needing a return spring for the fertilizer door/blade. Any help available? Thank you.
Where can I get a return spring on the gearbox from for my Honda HRB535 petrol mower?
lots of different types of springs you can buy
for that
any honda mower shop for the spring ..
http://www.zeppy.io/discover/gb/honda-hrd
are you looking for clutch return spring ?
Sep 10, 2016 • Garden
How dose the line return spring install can't really tell how to install it please jelp
nstallation of Wolff trigger return spring??? - The Firing Line ...
https://thefiringline.com/forums/showthread.php?t=132371
Sep 28, 2002 - 10 posts - ‎4 authors
I know how to install the main spring. How do you install the trigger return springthough? I'm asking cause I just ordered the Wolff GP 100 ... GP100 - Hammer/Trigger Spring Questions
Aug 8, 2012
Changing Springs in SP101
Apr 8, 2011
Wolff replacement main spring for S&W?
Apr 6, 2011
Show of hands...CZ trigger return spring
Feb 19, 2007
More results from thefiringline.com
RG 150 kickstart not returning
The spring must be "wound" to be tight and make the kickstart lever return..
1helpful
How to change rear barke shoes
Brake Drums & Brake Shoes Removal & Installation To Remove:
  1. Raise and safely support rear of vehicle.
  2. Release parking brake.
  3. Remove rear wheel assemblies. NOTE: If brake drum is stuck, install two 8 mm bolts into threaded holes and tighten evenly.
  4. Remove top return spring, front and rear shoe spring clips and hold-down pins.
  5. Remove anti-rattle spring and adjuster spring. NOTE: Note position of operating lever prior to removal.
  6. Remove bottom return spring.
  7. Remove clip and washer and detach parking brake cable from rear shoe.
  8. Remove brake shoes.
To Install:
  1. Lubricate all brake shoe contact points with appropriate grease.
  2. Place operating level into position on hub.
  3. Install rear brake shoe and connect parking brake cable to rear shoe with washer and clip.
  4. Install front brake shoe and install bottom return spring.
  5. Install hold-down pins and spring clips.
  6. Position operating lever and install top return spring.
  7. Install anti-rattle spring and adjuster spring.
  8. Install brake drum and screws.
  9. Adjust brakes and install rear wheel assemblies.
2helpful
Remove and replace rear brake shoes on 2004 honda accord
  2. Remove rear wheel assemblies.
  3. Release parking brake.
  4. Remove brake drum.
Rear brake shoe assembly
  1. Using an appropriate brake spring tool, unhook upper return spring from rearward brake shoe.
  2. Push retainer springs IN and turn to remove tension pins.
  3. Lower brake shoe assembly and remove lower return spring.
  4. Remove brake shoe assembly from back plate.
  5. Disconnect parking brake cable from lever and remove brake shoe.
  6. Remove parking brake lever from brake shoe.
To Install:
  1. Install parking brake lever to rearward brake shoe.
  2. Secure lever to brake show with a NEW U-clip.
  3. Pinch U-clip closed.
  4. Connect parking brake cable to rearward brake shoe.
  5. Install self-adjuster lever spring on front brake shoe.
  6. Assemble clevises, adjuster bolt and upper and lower return springs.
  7. Apply a light coat of grease (Molykote 44MA or equivalent) to sliding surfaces.
  8. Install brake shoe assembly onto back plate.
  9. Install tension springs.
  10. Using an appropriate brake spring tool, unhook upper return spring to rearward brake shoe.
  11. Install brake drum.
  12. Install rear wheel assembly.
  13. Lower vehicle.
  14. Adjust self-adjusting brakes by pressing brake pedal several times.
1helpful
Return spring keeps on letting loose and doesn't work
Spring is broken. Sometimes hard to see. Hopefully is is at the end or close where the spring hooks to the housing. All you will have to do in that case is bend the spring and place back in slot. If broken in the middle, you will have to replace spring. Spring may be hard to find but you may find one on ebay or one of the saw forum sites. Just type McCulloch + the model no in google.
1helpful
Poulan 3400 chainsaw throttle trigger
Its a missing or broken spring in the handle(trigger). If you look inside the handle you should see a circular spring around the post of the trigger. This spring returns trigger to idle position. If its missing or broken the trigger won't spring back.
Top Powermatic Drills Experts
ADMIN Andrew
ADMIN Andrew
john h
Steve Pack
Steve Pack
Are you a Powermatic Drill Expert? Answer questions, earn points and help others
