Bulova Men's Watch Logo
Anonymous Posted on Jan 06, 2008
Setting the darn thing
I have my (deceased) brother's 1991 Bulova Marine Star Watch. It has a crystal at the 3:00 position and a button at the 9:00 position. It has a white face with FOUR black dials one each at the 12, 3, 6 and 9 o'clock positions. The black dial at the 12:00 position has a 12, 18, 24 and 6 (9?) at the 12, 3, 6, and 9:00 positions respectively. I don't understand what this is for unless it's just military time, but I can set this dial by pulling the crystal out to the intermediate position and turning. The days of the week are on the black dial at the 3:00 position and I can set that. The black dial at the 6:00 position is the same as the one at the 12:00 position but is not in synch with it and I can't understand what I need two of these for anyway. The black dial at the 9:00 position is the days of the month and I can't figure out how to set this one either. What is the trick?
  • Anonymous Jan 08, 2008
    Thanks for the help. The code under the six says MOVI JAPAN 90004 or 90D04, I think. I tried all combinations of this and I couldn't get an answer. I guess I'll have to try a watch shop to see if they can help. Thanks again.
Anonymous
Level 2:
Sniper:
  • Expert 73 Answers
  • Posted on Jan 07, 2008
Anonymous
Expert
Level 2:
Sniper:
Answers
73
Questions
Helped
157072
Points
277
If you don't have the instruction manual you can go to this link and on the right side of the page you can type in the model number. (it will tell you where to locate the model number) I tried this for a Bulova from 1998 and it worked but I don't know how far it will go back but it's worth a try.
http://www.bulova.com/service/instructions.aspx
2answers
I need a manual for a bulova model 90a07.Is there a manual or download available? It's a cronograph alarm.
https://www.youtube.com/watch?v=UR9yVjrFyiE
This is merely a video on how to reset the second hand on your Marine Star.
But perhaps it has some information that will be helpful to you.
2answers
What are the functions of buttons on 98B106
I was unable to find the model 96B106 in their range but I did find 98B106. I this is the watch you have, then go to http://www.bulova.com/watches/bulova/marine-star/98b106/ and download the usermanual.
2answers
Bulova Marine Star with chronograph. The minute hand of the chronograph resets to the 'one minute' location, not the top of the dial. I tried pulling the dial out and pushing the 'A' button and let the...
I have the exact same issue with the minute hand resting at the 1 minute mark and now I have condensation under the glass. The watch is only 2 months old so I think I will return it.
I NEED INSTRUCTIONS FOR MY Bulova 98B013 Marine Star watch for men where can I locate more instructions
You can get the .pdf here:
http://www.bulova.com/brands/bulova/product.aspx?origin=sku&sku=98B013&brand=bulova
Bulova Marine Star 98B103 chronograph not working
The instructions seem simple enough and if the watchfails to operate correctly, I suggest that you return it under the warranty.
How to change the time on Bulova Marine Star 100m. This is an old watch with 4 stems. 2 on each side. One is an on/off stem which is on the right side of the face.
1st: make sure the watch is set to "tme" , the botton dail display, press bottom right stem
2nd: pull out the bottom right stem ,
3rd: press the left top stem for increase time . i.e. 2:40 pm to... 2: 45pm
4th, or press the left bottom stem for decrease time: i.e. 2:40pm to .. 2:30 pm
5th: once time is good, then press in the right bottom stem,
2answers
Need operators manual for a bulova marine star 90A07
While I can find "Marine Star" in the list of models, I could not find one with the same refernce number.
There are a number of models so if you go to http://www.bulova.com/brands/bulova/bulova.aspx?brand=bulova#coll_id=30&coll_name=Marine%20Star&gender=1 ", you may be able to find one that looks like yours.
If you click on a watch, details appear and these include operating instructions.
I need the watch band for bulova marine star 98c69
if you want a original you need the serial number of the back...try bulovas website or ebay worldwide...from the picture it looks like you will need a original as it looks like its integral to the watch case so prob bulova only try them direct before going to a jewelers or watch repair company...
I need a manual to operate a bulova 98G70 marine star wrist watch
Copy "http://www.bulova.com/brands/bulova/bulova.aspx?brand=bulova#coll_id=30&coll_name=Marine%20Star&gender=1" into your search engine and you should arrive at the Boluva web site page listing Marine Star models.
I couldn't find your particular model but perhaps one of those listed is similar to yours.
22helpful
4answers
How to set time on a bulova marine star 96C30
For some reason you cannot find the manuals on the Bulova web site any longer. But don't worry....
I have the manual for the Bulova Marine Star 96C30 Watch. This is easily fixable.
Below, I have typed the instruction on how to fix this issue as well as reset the time and calendar and a few extra tips in case you forgot....
Here is what it says to do if the hands don't match up with the display time (usually happens after you change the battery).
First, you must locate the buttons on the watch.
The "A" button is at the 2 o'clock position (upper right). The "B" button is at the 10 o'clock position (upper left) The "C" button is at the 8 o'clock position (lower left) The "M" (mode) button is at the 4 o'clock position (lower right), and is the only button you can pull out to set the times, calendar and programming.
To RESET the watch and do the ZERO POSITIONING after changing a battery or having a display error, do the following.
RESET 1. Pull the "M" button out to the setting position. 2. hold down the "A", "B", and "C" buttons simultaneously for 3 seconds, then release them. All digit segments will turn on and display completely.
ZERO POSITIONING 1. Press the "B" button and all the segments in the digital time will reset to zero, with "UTC" showing in the main digital window. 2. Zero the "UTC" minute and hour hand (located in 12 o'clock sub-dial) to the 24 o'clock maker (straight up). Button "A" will move the hands clockwise, and button "C" will move the hands counter clockwise. 3. Press button "B" - "HR" shows in the main digital window. Adjust the main (large) hour hand to the 12 o'clock (midnight) position using "A" and "C" buttons. At the same time, observe the synchronized 24 hour hand (small dial to the left of the main dial), to insure that it also moves to point to "24". 4. Press button "B". "MIN" shows in the display window. Adjust the large minute hand to also point to the 12 using the "A" and "C" buttons. 5. Push the "M" (mode) button back in to its normal position. The watch beeps and at the same time the hands jump slightly. ALL RESET and ZERO POSITIONING are now complete. 6. Reset the time, calendar and other modes.
To set the time. Note that changing the time in any of the cities will automatically update the time for all the cities. 1. Press the "M" button to move the mode hand to (TME) 2. Press either the "A" or "C" button to move to the desired city. 3. Pull the "M" button out to the setting position. 4. Press the "A" button. SECONDS will blink. Set them with "C". 5. Press the "A" button again, and MINUTES will blink. Set them with the "C" button. 6. Press the "A" button again, and HOURS will blink. Set with the "C" button. 7. Press the "A" button again, and 12 or 24 hours tim format will appear. 8. Push in the "M" button to its normal position.
To set the calender 1. push the "M" button to move the mode hand to (CAL) 2. Set the city using the "A" or "C" buttons. 3. Pull out the "M" button to the "setting" position. The numbers of the "month" starts to blink. this is an "american" date system with the month first, day second, and year third. Use "C" button to adjust the month. 4. Push the "A" button. The date (day) will flash. Adjust with the "C" button. 5. Push the "A" button. The YEAR flashes. Adjust with the "C" button. 6. Push the "M" button back in. The calender is simultaneously adjusted for all cities.
Couple of other "tips".
Switching the time on the digital display with the time shown on the hands: 1. Press the "M" button until the mode hand is in (TME) or (CAL) mode. 2. Pressing the "A" and "C" button together. The time will switch the between the main hands (analog) and the digital display.
Temporary Hand Retraction Pressing and holding the "B" button will move the hands out of the way of the display. Repressing the "B" button will put the hands back at the correct time.
hope this helps.
Top Bulova Watches Experts
ZJ Limited
ZJ Limited
NOEL
NOEL
Are you a Bulova Watch Expert? Answer questions, earn points and help others
