Planar PT1500MU 15 in. Flat Panel LCD Monitor Logo
Posted on Mar 21, 2017
My monitor's on-screen menu (osd-control, auto adjust, etc) has come up on the screen and just sits there, flashing through its options, on top of everything else in the lower right-hand corner. It is supposed to be controlled by the buttons at the bottom of the monitor, but they don't do anything. The power button doesn't even work any more--I have to turn it off with the switch on the power strip! This monitor worked fine for about a year, but this problem has been ongoing for a couple of weeks and does not go away when I turn off or reboot the computer. The only thing i have not tried yet is disconnecting and reconnecting it, because that is kind of a pain. Is that what I have to do, or is there another fix? Will that even help? Thanks, Ali
2 Related Answers
A
Anonymous
  • Posted on May 29, 2008
SOURCE: OSD Menu won't turn off
its not working
Anonymous
  • 258 Answers
  • Posted on Apr 11, 2010
SOURCE: Monitor control panel comes up for no apparent
This sounds like a problem with one or more of the buttons on the monitor itself being stuck on, or a fault in the circuitry connected with the buttons.
Check for grit etc. in the buttons, maybe try cleaning with a soft brush while unplugged from power.
How to unlock buttons?
Not sure if this is exactly the same as yours your model hard to find I had 2 similar monitors at previous employer and they both operated the same way Taking a Look 1. Power Switch Pressing this button turns the display system power on or off. 2. Menu/Select ? Pressing this button pops up the OSD menus on the screen, and used to select ("Up" direction) the OSD control options on the screen. ? This button is used to select ("Down" direction) the OSD control options on 3. Select the screen. 4. + This button is used to increase the value of the selected OSD control option. 5. 0 This button is used to decrease the value of the selected OSD control option. Quick Adjustment Function When the OSD Menu is not active, the following functions are available for the quick adjustment. Pressing ? button once pops up the OSD Function Main Menu . Pressing ? button once pops up the small Brightness icon. Use +or 0button to adjust the Brightness level. Pressing + button once pops up the small Volume icon. Use +or 0 button to adjust the Volume level.
If you need further help, reach me via phone at https://www.6ya.com/expert/richard_b70d968cd1a1d293
Cant get my monitor back in english its on *** i think
restore your settings to "Factory Settings" by
use the front panel buttons
Power Turns the monitor on and to standby or sleep mode.
? NOTE: The power button is located on the top or front of the monitor depending on the model.
- Menu Opens, selects, or exits the OSD menu.
-Adjusts the volume level.
-Opens the Quick View menu to quickly adjust settings for gaming, video, photo, and text.
? Navigates backward through the OSD menu and decreases adjustment levels.
+ Navigates forward through the OSD menu and increases adjustment levels.
Auto Auto-adjusts the display
Select Enters the selected option.
7helpful
"OSD LOCKED" box on my screen
The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock displays for ten seconds.
* If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
* If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD.
OSD stands for "On Screen Display." It is an onscreen configuration menu included with various monitors. When you press the MENU button or one of the other buttons on the front or side of a monitor, the onscreen display may appear. The OSD typically includes monitor calibration options, such as brightness, contrast, and color adjustments. Some OSDs may also include horizontal and vertical position controls as well as tilt and keystone adjustments.
If you can't make adjustments to the monitor settings using the OSD interface, the onscreen display may be locked. You may also see the phrase "OSD Locked" appear when you try to change the settings. Some monitors include an option within the menu called "OSD Lock", which you can turn on or off. If this option is available, simply turn OSD Lock off and you will be able to make adjustments to the settings.
If your monitor does not include the "OSD Lock" option, you may be able to unlock the OSD by pressing and holding the MENU button on the front or side of the monitor for several seconds. If you try this method, be patient! It may take up to 15 seconds for the OSD to unlock.
VOTE ME
Unable to adjust the settings for brightness and contrast .
To adjust the display settings:
1. Press the flywheel control. The main menu appears.
The current display settings appear across the top of the main menu.
2. Rotate the flywheel to highlight an option. The name of the
highlighted option appears in the center of the menu.
3. Press the flywheel control to select the highlighted option, then
rotate the flywheel to adjust it.
Some options can only be enabled or disabled. There are also some
options that contain additional menus.
4. Repeat Steps 2 and 3 until you have made all your changes.
5. Rotate the flywheel control until Exit is highlighted, then press
it to exit the OSD control system.
OSD OPTIONS:
Contrast increases or decreases display image contrast.
Brightness increases or decreases display image brightness.
Horizontal Size increases or decreases the width of the display image.
Horizontal Position moves display image to the left or right side of
the screen.
Vertical Size increases or decreases the height of the display image.
Vertical Position moves display image to the top or bottom of the
screen,
Pincushion curves the sides of the display image inward or outward.
Trapezoid increases or decreases the trapezoid distortion of the
display image.
Degauss removes magnetic discoloration from the display image.
Recall returns most options to the original factory default settings
if the monitor is currently using a preset video mode. (See the “Video
modes” section in this guide for information about the factory preset
modes.)
Advanced Option opens the Advanced Option menu. Color opens the Color
Manager menu.
Language changes the display language for the OSD control system.
User displays information about the monitor’s preset modes.
OSD Manager moves the OSD control window on the screen.
Exit closes OSD control system.
1helpful
Im trying to adjust my philips lcd but menu says "osd main control is locked" how can I unlock it?
In order to resolve the OSD menu locked error:
1. You must reset the on screen display in the menu.
2. Hold down the Menu button for at least 60 seconds.
3. A menu list will appear on your monitor screen.
4. Using the adjust button, press the arrows to enter the menu.
5. Scroll down to the Reset section.
6. On the right side of your screen, you will see an alternating Yes/No choice.
7. When the Yes message flashes, press the Ok button.
8. The menu should be reset and the flashing OSD control message should disappear.
How do i do a full reset? I would like it back to factory settings.
Click on Start, All Programs and click HP My Display, Again Click HP My Display and than you can follow the on screen display to reset it.
Also you can use the front panel buttons
– Navigates backward through the OSD menu and decreases adjustment levels.
2answers
There are buttons on the front of the monitor. Why
The first button is the E-power button for the Auto preset function.With it you can select presets like text, standard, graphics etc. depending on your use.
When you select any button the options are displayed at the bottom of the window. These tell you what button to press to select the next option.
For example press --menu-- > -- > -- menu , to adjust the horizontal and vertical position.
To turn off the monitor you must press and hold the --circle with the line -- button for a couple of seconds.
1helpful
My computer screen has a blue box that pops up and say "Controls locked". I am assuming that the buttons on the bottom right hand corner of my moniter is what it is talking about because when I hit the...
This is from the user manual for the monitor. You can download a copy from hp here:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=324216&os=228&lang=en&
Click on the "monitor user's guide" link to download.
There are four adjustable options on the OSD settings screen: Lock OSD settings, Timeout, H Position, and V Position.
To change OSD settings:
1 Open the OSD setting screen under the Advanced menu. See
“Using the On Screen Display” on page 25.
2 Press the Browse buttons to select the option you want to adjust.
3 Press the Select button to check the option.
To change OSD lock setting:
1 Press the Browse button to select yes (lock) or no (unlock). The
setting is automatically saved when you change the value.
2 Choose Exit sub-menu and press the Select button to return to
the OSD Main Menu or press the Menu button to exit OSD.
NOTE: Once OSD is locked, all OSD functions including the
shortcut buttons are disabled. If OSD is locked, pressing
any button on the monitor directly opens the Lock OSD
settings window so that you can unlock OSD.
282helpful
25answers
Osd main controls locked/unlocked pops up every 5 seconds
Press the Menu button ( marked OK) for one minute, or more, and a blue/red menu list should appear on screen.
Using the adjust button (immediately to the left of the OK button) by pressing the arrows at each end up or down as required you can enter the menu and select an action by scrolling.
At the end of the list of possible adjustments on the left of the screen (brightness, contrast, etc) is the Reset section.
On the righthand side of the screen is a flashing Yes No choice which automatically alternates.
The trick is to select the Reset choice on the left and while selected press the OK button when the Yes alternative on the right of the screen is flashing.
You VDU should then Reset and all will be well.
Screen ajustment
Hi stefan,
You can adjust manually using the OSD (on-screen display) menu of you monitor by pressing menu button. Other monitor OSDs cannot be accessed on single button but some combination of buttons but considering it can be accessed, please look for it. Try also changing the properties at Operating System GUID (graphics user interface display) Control Panel Display or your monitors display monitor application software. Try changing the frequencies and other special features like single screen or wide screen, etc..
Best regards,
Rosener
Top Planar Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Planar Computer and Internet Expert? Answer questions, earn points and help others
