20 Most Recent Planar PL1700 17" Flat Panel LCD Monitor Questions & Answers
Planar PL LCD Monitor Fix - MarsBox.com
marsbox.com > Blog > Howtos
Nov 3, 2008 - Planar PL LCD monitor has flashing power led with no image. ... You will know it worked if the monitor diplays "No Signal" message when ...
What is the method to reset the Planar 1910m monitor?
superuser.com/.../what-is-the-method-to-reset-the-planar-1910m-monitor
Apr 6, 2010 - My monitor (a Planar, apparently model number PL1910M) is not working. (It is flashing a green / orange sequence which I believe to be an error code. The sequence, in ... I wasn't even seeing a "no signal" message and I couldn't turn it off using the power button. ... Computer resets when put under load.
ViewSonic VX922 monitor - black screen - green power light flashes ...
www.tomshardware.com > Forum > Displays
Tom's Hardware Guide
Feb 1, 2008 - 50 posts - ‎27 authors
Repair ViewSonic VX924 LCD Monitor Blinking Green power Button ... cant switch back & forth to desktop out of some games without the monitor going .... Nothing else on the board looks bad, the power supply board is dark brown ... to this madness we are unfortunantly dealing with daily with our monitors.Missing: planar ‎pl1700
Planar PL1700... | Answered on Jan 05, 2016
Please refer the "Chapter 2" (Page No. 6) of the User Manual. Click HERE to open/download the User Manual.
Let me know if you have further problem.
Good Luck.
Thanks for using FixYa.
Planar PL1700... | Answered on Nov 03, 2012
That is not a good sign, this indicates the LCD panel display is failing, I would use until it completely goes, and replace the monitor with a new one , cheaper in the long run.
Planar PL1700... | Answered on Apr 23, 2012
you'll need one of these
http://store.apple.com/uk/product/M9320G/A
mac mini dvi to vga adapter
Planar PL1700... | Answered on Apr 05, 2011
Not driver problem.
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Planar PL1700... | Answered on Mar 30, 2011
When it lights up the orange light, that means that the monitor is not getting a signal from the computer.
The things to try (from simplest to most complex) are:
  1. Make sure the computer is on and not in "sleep" mode -- press the "Caps Lock" key and see if it lights up the caps-lock light on the keyboard.
  2. Make sure the video cable is connected from the computer to the monitor (that the cable hasn't come loose on either end)
  3. If your monitor has multiple inputs, make sure it's set to the right (probably analog VGA or DVI) input
  4. If your computer has more than one video output (like a laptop with it's internal screen plus the external monitor) then make sure the external monitor is enabled
If none of those solve it, post a comment back here and we can dive in to the more complex tests
Planar PL1700... | Answered on Feb 09, 2011
this is a common problem with the capacitor, try opening your monitor and see if there is a capacitor swalow like gonna blow... the capacitor has a form like a AA battery... if changing the capacitor the problem persist maybe is a problem with the board and you need to search if the board have continous power....
Planar PL1700... | Answered on Jul 30, 2010
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
Planar PL1700... | Answered on Jun 06, 2010
It is not reset problem, more likely to have failure inside the monitor.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Planar PL1700... | Answered on May 17, 2010
I assume that you have already try it with other PC with the same result, also try new VGA cable. Just want to narrow down the problem before start taking apart the monitor.
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Planar PL1700... | Answered on Apr 01, 2010
Check here on how to determine the CCFL size without taking the old one out first (best to remove the old first), WWW.LCDPARTS.NET
http://lcdparts.net/howto/selectccfl.aspx
Planar PL1700... | Answered on Jan 25, 2010
uopftball, You will need to see some of the longer (6 to 10minute) video clips of "LCD monitor disassembly" / "LCD monitor repair" @ YOUTUBE and understand some basic principles of how a typical lcd monitor lights-up it's LCD glass panel. As for being the "same" concept as a laptop, Yes! and NO. Do you know anything about how the fluorescent lamps are lit on the rear side of the lcd panel? Changing a lcd on a laptop is not same as inspecting and repairing a switch-mode-power-supply or CCFL inverter (electronic ballast) power supply. The hardest part of monitor disassembly is removing the plastic rear cover from the plastic front bezel. There are usually 2 or 3 printed circuit boards( 3 in older) Inspect the SMPS for frosty looking COLD solder joints and bad electrolytic filter capacitors (swollen and possibly leaking) Pics can be viewed @ www.ccl-la.com/badcaps.htm and all over the net. let me know what you find inside the metal ventilated covers on rear of lcd panel. 12fixlouie
Planar PL1700... | Answered on Dec 09, 2009
mrjk65, If monitor still has bright, crisp images displayed on the LCD panel your monitor could be worth saving! Unplug unit from wall outlet and plug it back in! If same problem occurs then most likely problem could be a DC voltage is slightly "out of spec" or a settings panel push switch may have failed. My guess is that when STRANGE out of the BLUE things start to happen for no reason, I would suspect the "switch-mode-power-supply" to be the item at FAULT. Visit YOUTUBE for vids of "LCD monitor disassembly" , "LCD monitor repair" . You will be glad you did. Also try www.ccl-la.com/badcaps.htm , www.lcdparts.net , www.badcaps.net for more info. hope this helps. Bye for now. 12fixlouie.
Planar PL1700... | Answered on Nov 08, 2009
The inverter in the monitor is probably going bad. It can be replaced, depending on the size/age of the monitor. Many times it is cheaper to buy a new one than to have it fixed.
If you are a little handy, and can get the monitor open, you can find the inverter and replace it. The monitors have a high voltage area you have to be very careful around.
New inverters range from $30-75. They are very specific to the model of monitor. The best way to find one is to get to the inverter and search for the numbers printed on it.
A repair might cost you $100+
Planar PL1700... | Answered on Apr 03, 2009
Planar PL1700 17" Flat Panel LCD Monitor Logo
34 questions posted
Top Planar Computers & Internet Experts
Thomas F. Schneider
William Miller
William Miller
Steve Allison
Steve Allison
Are you a Planar Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Planar Computers & Internet
Most Popular Question
turn oranges light will
  • Computers & Internet
