You can buy a new plastic slide from a company that sells swing sets, but the slide is probably going to cost more than a whole new swing set. The slides can be pricy when purchased separately. You might want to consider upgrading and going with a new, sturdier swing set. As far as I know, there is no way to repair the cracked slide since it is molded plastic.
Dear Sir:
Turn off the power to your computer and unplug all cables connected to it. Remove the battery, if one is installed.
Locate the covered screws around the cracked screen. Remove the rubber or plastic covers, then unscrew the screws.
Gently remove the plastic frame around the cracked screen and set it aside. Disconnect any power cords or cables going into the LCD screen.
Remove the cracked screen and slide the new screen into place. Replace any tape or plastic fasteners that hold it in place.
Reconnect all internal cords to the screen. Screw in the frame and replace all the screw covers.
Reconnect the power supply and all external cables to the LCD screen and switch it on.
sincerely. God bless you
ernesto cuadra
managua, nicaragua. c.a.
