GE Advantium SCA1000H Convection / Microwave Oven Logo
Posted on Nov 04, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
GE Advantium 120 sca1000dww03. Broken door handle
I have a GE Advantium 120 sca1000dww03. The door handle has broken off. I have a replacement handle but am having trouble getting access to the bottom screw inside the door panel. I have removed the cover by prying it up around the door, but I think I have broken the tips off most of the small black hooks. I can't seem to get the metal inner panel out of the door to allow access to the lower screw. I have removed the six screws holding the metal paneI in place and I can pry up two or three of the clips at once but cannot seem to get the panel out! Any suggestions? Ken
  • schuberth Nov 04, 2009
    Thanks for your advice. I worked on it and then discovered that if I bent the metal flanges near the clips inward a little it loosened the plate enough to "pop it out" just as you said. After I popped it back in, I straighted the metal flanges and put everything back together!
    Thanks again!
    Your advice to pull on it and it would pop out encouraged me to work on it. I discovered that by bending the metal flanges around the clips inward a little, it loosened the plate and allowed it to come out! I simply bent them back after I popped the inner shieldback in! Thanks.
Anonymous
Level 3:
President:
  • Master 1,304 Answers
  • Posted on Nov 04, 2009
Anonymous
Master
Level 3:
President:
Answers
1304
Questions
0
Helped
367595
Points
3700
The screen should pop up it may take a li but it will pup up and out very similar to the cowel
its a lil tough but it will lft out
The handle of my Advantium 120 has broken off. Can this be repaired and can be done by us or a service repair man?
It can be replaced by either a repair person or if you can source the part, yourself as it is part of the frame and not the high voltage electrical stuff inside.
How to remove the outter door frame on the GE Microwave
http://www.repairfaq.org/sam/micfaq.htm
for both queries this site would help somethin i think.. tpugh information is very huge please see if it is useful for u
Handle broken off the door of a black advantium 120
The handles are usually held on by two screws which are usually visible on the back of the door. The handle itself should be available at some of the parts suppliers who sell on the internet.
4helpful
2answers
The door handle on my GE Profile ADvantium 120 Microwave is broke
appliancepartspros.com. part number AP3187809 $56.40 plus shipping
How to Replace Broken Handle
Sorry but the chat system seems slow and hard to work with.
Page 28 & 29 of the service manual tell you how to remove the door and take it apart to replace the handle.
The service manual is here.
And you can watch a YouTube video (not a video I made) that demonstrates how it's done.
6helpful
2answers
Broken Bottom Latch Pawl GE Advantium 120 Microwave
You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
4helpful
Advantium 120 door handle breakage
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
Need to Replace Door Handle for KitchenAid Over Range Microwave Hood Combo KHMS147KSS
Check out this door frame diagram, specifically number 1805. It clips on to the door frame. Remove it using a dull table knife or something similar (be careful not to scratch or break anything). You will then have access to the bottom screw.
1helpful
2answers
Broken handle
I used a form of hot stuff glue and it worked just fine!!
Top GE Microwave Ovens Experts
vince
NOEL
NOEL
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
