Sounds like you've never lubricated the belt. This has caused frequent overheating issues so now at higher speeds, the motor control board overheats and shuts down.
You'll have to first loosen the belt, then lubricate it. After words, tighten the belt again, if at all possible, don't tighten it as much as it was before, as overtightened belts are often a contributing factor.
Then calibrate the treadmill, make sure you are using a surge supressor and you hould be good for a while.
ERR1
indicates a speed issue. In this case, the motor speed as reported
from the optic sensor differs
from
the speed setting.
Analysis:
Optic sensor signal issue -- Either the optic sensor signal is not
right, or it is read incorrectly, or
the
signal is not reaching the display.
clean the speed sensor, test for open or faulty. tight the connector very well. RUN the software calibration for easy troubleshooting and fix it.
see the diagram attached. and follow steps.
God bless you
Version:1.0
StartHTML:0000000168
EndHTML:0000003648
StartFragment:0000000468
EndFragment:0000003631
The
Steps for Newer Style Console Calibration
Locate the calibration area on the
rear or underside of the console (a hole, near the console's center,
that goes through to the electronics board. (This hole should not
have a screw in it.)
Insert a pencil (eraser end),
into the hole and feel around for the cal button (will click
when pressed).
Press the button 2 times
(with the pencil eraser). The first click should show CL11
in the console, the second click should show CL21.
If the process was done correctly,
and CL21 appears in the console, you are in "calibration
mode." The next few steps consists of pressing buttons
on the console and observing settings. This will not require
any other tools.
Press ENTER. CL22 should display
in the TIME window and (??) in the SPEED window.
Press ENTER. CL23 should display
Press ENTER. CL24 should display
Press ENTER. CL25 should
display in the TIME window and (??) in the SPEED window.
Press ENTER. CL26 should
display in the TIME window. You should then see the
letter "E."
Press ENTER. You should see "SS"
or "55" in the console.
Push the STOP/START button. For
safety, at this point, you should step off, or be off, the
treadmill.
Push the ENTER button. The walking
belt should start to move, accelerate to maximum speed, then stop on
its own.
When the belt stops, the
incline should self test by raising to its highest
incline position, then lowering back down to its lowest
position.
Once the incline test is complete,
push the POWER button 2 times. The unit should shut off and the
console should go completely blank. If this happens, the
treadmill is done calibrating and is ready for use.
