Minn Kota Riptide St Saltwater 80 Bow Mount Trolling Motor Logo
Posted on May 24, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need a replacement top for the MinnKota Riptide 80 trolling motor mount as two of the six plastic screw mounts are broken. Also, the plastic washer around the handle mounts that are inside the mount are also broken. I need replacement parts for both as the motor is now apart and does not function well without these items. Can't seem to find them on-line anywhere. Motor will be 2 years old in December and I don't want to have to buy another one because of a $20 part. Any help will be appreciated.
Steve P
Level 3:
  • Minn Kota Master 3,912 Answers
  • Posted on Jun 14, 2017
Steve P
Minn Kota Master
Level 3:
Answers
3912
Questions
5
Helped
1307945
Points
15904
These guy will take care of you,
http://www.jonestrollingmotor.com/
1 Related Answer
Editor925
Dean
  • 285 Answers
  • Posted on Mar 17, 2009
SOURCE: Mounting a sonor/transducer on a MinnKota Riptide ST
Did the unit come with a strap to mount the transducer to a bow mount electric? Most units do... If not there is probably one available for the unit as an aftermarket accessory or accessory from the manufacturer... Regarding the transducer wire, just wrap and rout this up the front of the bow mount motor shaft so when you pull the motor up and secure it, it is not going to get in the way. You could cable tie the cord down near the bottom of the shaft and one up near the top where they wont interfere with the motor bracket when the motor is positioned up on the boat.
Motor has power but won't do anything won't turn on or steer
Hi I have a minnkota I pilot. I use with a remote control. For some reason there is power going to it but won't anchor lock or turn left or right. What could be the problem
I have a minkk kota riptide salt water bow mount trolling motor. The motor functioned properly last time out. This time the motor failed to come on. one of the batteries was found to be bad and...
Many times on the battery lead, actually the part that tightens to the battery, has a circuit breaker. You will notice a small reset button on each positive lead....of course there are two for a 24v system. Reset each one!
I have a Minnkota Riptide 80# thrust trollmotor.I have power to the head but motor will not run. It is a bow mount with twist grip control.When I mash on the power indicator button ,it lights up showing I...
1. possibly a broken connection to the motor where the propeller is located. 2. Also could be a bad motor. 3. Look for a fuse location for a possible blown fuse to the motor. 4. motor brushes could be the problem.
Online manual needed
I have minnkota riptide i had to take the handle off and a little spring & white plastic piece poped out of the handle i just wanted to see where it goes
2answers
Bow mount 80lb to transom mount
Parts can be purchased from this dealer...There are schematics on the site for review....
http://www.northlandmarine.com/MinnKotaQuickRef.htm
2helpful
2answers
2helpful
How to install trolling motor
If it is a bow mount model, then you basically need a bow mount bracket attached to the bow of your boat. If one didn't come with the outboard, you will have to buy one from the same manufacturer or an after-market one suitable for your boat. If in doubt, consult the local boating or marine store or wherever you purchased the motor or the bracket from.
Top Minn Kota Boating Experts
ADMIN Andrew
ADMIN Andrew
john h
vince
Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
