This set has a power button on the far right of all the buttons on the front. I looked at page 11 of the owners manual http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000001840.pdf and it shows it very clearly. It looks as if the power button may be turned the opposite way from the other buttons. Thanks
[3] Find the "Recall" or "Setup" button on the Toshiba remote control. After you find it, press and hold down that button until the lights on the remote control turn on and remain lit. [4] Point the Toshiba remote at the device you turned on in Step 2 and press the button on the remote for that device. [5] Begin pressing the "Power" button on the Toshiba remote. Continue doing this until you have turned the device off using the Toshiba remote. Once it shuts off, press "Enter" on the Toshiba remote. The remote will then be programmed. OK.
1. Make sure there are working batteries in the Toshiba remote control.
2. Turn on your television set, DVD player or other device that you want to control with the Toshiba remote.
3. Find the "Recall" or "Setup" button on the Toshiba remote control. After you find it, press and hold down that button until the lights on the remote control turn on and remain lit.
4. Point the Toshiba remote at the device you turned on in Step 2 and press the button on the remote for that device.
5. Begin pressing the "Power" button on the Toshiba remote. Continue doing this until you have turned the device off using the Toshiba remote. Once it shuts off, press "Enter" on the Toshiba remote. The remote will then be programmed
OK.
