20 Most Recent GE 19TVR62 19 in. TV/VCR Combo Questions & Answers
On the back of the TV/VCR unit there is an input for audio & video plugs. These will accept a composite video signal and mono audio signal. I'm not sure if newer roku has these outputs as they are low def only signals. The roku would need to have have red, white & yellow sockets. (Old Roku's had these....) Yellow is video, red and white are L & R audio. Use a y adapter to merge red & white together, and use a standard RCA patch cord to connect the roku composite outputs to the TV VCR inputs.
GE 19TVR62 19... | Answered on May 06, 2014
There seams to be a problem with the tube ,likely not worth fixing this day and age ,tvs are quite cheap .
GE 19TVR62 19... | Answered on Jun 20, 2012
That sounds like dirty heads. Try a cleaning tape, but I have never had those work. You need chammy swabs, and rubbing alcohol and you clean the heads manyally. Hopefully your vcr comes out with only a few screws.....
Clean the heads parallel to tape path, not up and down the video drum. If you do parallel direction, it is hard to damage the heads...
Clean other items along the tape path and remove all hairs that you can find..but hte heads are the part not working, common for tape dust to accumulate and harden.
GE 19TVR62 19... | Answered on Feb 02, 2011
most likely the controller it came with has the option on it probably abbreviated if not you will want to check the manual if you end up needing a manual download for the user guide let us know we can get it to you quickly
Hope this helped
Robb
GE 19TVR62 19... | Answered on Apr 29, 2010
Does TV play with tape in VCR? If the VCR is out of time then TV will shut off.
GE 19TVR62 19... | Answered on Nov 25, 2009
Try bon the back of the battery lid on the control
GE 19TVR62 19... | Answered on Jun 22, 2009
There is no reset, when a CRT stays in storage for prolonged amount of time, moisture can build up and when you plugged in, most likely a surge happened, and your tv I'm afraid is dead. use it as an excuse to get an LCD :)
GE 19TVR62 19... | Answered on Apr 04, 2009
when i turn on , few seconds later goes off ..help
GE 19TVR62 19... | Answered on Dec 16, 2008
On my GE Tv/VCR Combo I had a similar problem. Try holding down the Power button on the remote for at least 7 seconds. This disengages the parental controls. I found this solution on another website after my tv stopped working after my 20 month old played with the remote for a while. This solution was not in manual. I am assuming that he held down the power button for 7 seconds to engage the parental control. Hope this helps!
GE 19TVR62 19... | Answered on Dec 06, 2008
its hungry
GE 19TVR62 19... | Answered on Mar 02, 2008
I found these remotes control VCR's only when programmed into the DVD button. It even says on page one of the manual that the DVD button is for DVD's, TV/VCR's, VCR's, etc. I got code 607 to control my GE VCR (using the DVD button). If that doesn't work, try 572 647 563 609 644 645 or 531.
GE 19TVR62 19... | Answered on Dec 23, 2007
IF connectors for turners,call 1-800-223-3205 this is Electronix Parts ,also make sure your turner is ok other wise replace turner!
GE 19TVR62 19... | Answered on Nov 19, 2007
timer settings vary depending on the tv. I would recomend getting the brand and model number than going to the brands website, if you are unsure of the websie type the brand name into a search engine should provide a website address for that company, after that check their support page. lots of companies have forums you can post questions on, most also have downloadable user manuals. if all else fails send an e-mail directly to the support team. just be sure to be specific about the tv and the problem.
GE 19TVR62 19... | Answered on Jun 07, 2007
GE 19TVR62 19 in. TV/VCR Combo Logo
28 questions posted
Top GE Televison & Video Experts
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • GE Televison & Video
Most Popular Question
bad color
  • Televison & Video
