Hi Same problem but easy to fix.
Remove back cover of machine. Look to the lower end of the bowl and you will notice a stainless steel wire with hook attached. If this is hanging loose that will be your problem. Reattach the hook to the grey coloured lever , it has a hole drilled through it at the extremity. The wire pulls on this lever to disengage the drum brake during the spin cycle.
